Low Ceiling Fan
Hi guys,
I just bought a ceiling fan, 54" and got it install in living room and bedroom but both rooms also have false ceiling.
Living room is L-box so the total height from ground to fan is 2100 mm and bedroom is a bit shorter due to false ceiling only which the height is 2000 mm from ground to fan.
I checked the min height for safety reason is at least 2200 mm :( ... What can I do now :dunno: ? Cut the rod shorter??
  • 2 weeks later...
  • 2 months later...
this high is no suitable install ceiling for safe reason. i don't think your electrician cut the down rod for you.
you probably have to do something about the false ceiling.
