shockwave
4Room Bto (Without Tile And Door) - Is The Quotation Reasonable?
That seems more like a sales designer rather than you are dealing with ID, cause Designing is a very professional and Sacred job so it should not be FOC....
my designer told me this Yesterday and he hope the message can pass down to RT forumers:
"Anyone can be a designer but not everyone can do good design", 2 "Anyone can play guitar, but not everyone can write script"
Below is the 2nd quotation from another ID. This is more detail as what I want for my home.
1.0 - PROFESSIONAL SERVICES
1.1 Design consultation FOC
1.2 Space Planning FOC
1.3 Perspective Drawings FOC
1.4 Material & Colour Proposal FOC
1.5 Project Management FOC
SUB-TOTAL : $ -
2.0 - MISCELLANEOUS WORKS
2.1 To supply & paint of wall & ceiling for whole house include all expose $1,200.00
piping (Nippon/ICI paint)
2.2 To supply & paint existing door frames $100.00
2.3 To haulage material to unit c/w debris disposal and sand hualage $800.00
2.4 To supply labour for general cleaning whole house include acid cleaning for $280.00
floor, wall & window (02 times cleaning)
2.5 To supply & lay corrugated paper for floor/door protection purposes $180.00
SUB-TOTAL : $ 2,560.00
3.0 - PLUMBING WORKS
3.1 To supply labour to joint in/out let pipe for kitchen sink and tap $150.00
3.2 To supply & extended stainless steel pipe at kitchen sink $100.00
3.3 To supply & run 01 hand spray point for master toilet $30.00
3.4 To supply & run 01 hand spray point for common toilet $30.00
3.5 To supply labour to install toilet accessories at master toilet $ 45.00
3.6 To supply labour to install toilet accessories at common toilet $45.00
3.7 To supply labour to install heater (Storage @ common toilet) $120.00
3.8 To supply labour to remove exsiting basin at master toilet $35.00
3.9 To supply labour to install 01 no standard wash basin at master toilet $70.00
c/w lever tap (cold and hot water)
SUB-TOTAL : $ 625.00
4.0 - CEILING WORKS
4.1 To supply & install L-box light holder **** with plaster board $480.00
4.2 To supply & install false ceiling at dining with plaster board $480.00
4.3 To supply & install false ceiling at passage way with plaster board $200.00
4.4 To supply & install cover up for household shelter ventilation with plaster $80.00
board
4.5 To supply & install 24 ft curtain pulmets **** L-box with plaster board $240.00
SUB-TOTAL : $ 1,480.00
5.0 - MASONRY WORKS
5.1 To supply & construct 50mm fridge base with tiles finish $120.00
5.2 To supply & construct 50mm washing machine base with tiles finish $120.00
5.3 To supply & construct 50mm cabinet base with tiles skirting $320.00
5.4 To supply & construct shower curb/drop at master toilet with tiles finish $100.00
5.5 To supply & construct shower curb/drop at common toilet with tiles finish $100.00
SUB-TOTAL : $ 760.00
6.0 - ALUMINIUM / WROUGHT WORKS
6.1 To supply & install 3-track & panel sliding window at service yard with $600.00
accordance to HDB regulations c/w n/a finish and clear/black glass
6.2 To supply & install 115 sqf aluminium grills with n/a finish $690.00
6.3 To supply & install 3-track aluminium grills with n/a finish at service yard $320.00
6.4 To supply & install aluminium swing and slide door at master toilet c/w $380.00
acrylic series selections
6.5 To supply & install aluminium swing and slide door at common toilet c/w $380.00
SUB-TOTAL : $ 2,370.00
7.0 - CARPENTRY WORKS ****
7.1 To supply & fabricate 8 ft designed full height feature wall **** c/w laminate $1,680.00
laminated finish and stainless steel stripes
7.2 To supply & fabricate 8 ft designed TV consol with laminated finish and $960.00
aluminium framed glass doors
7.3 To supply & fabricate 120 sqft solid plywood platform with bare finish $1,440.00
(4'' high)
7.4 To supply & fabricate 12 ft designed storage bay window with laminated $1,920.00
finish, soft closing hinges and 3'' cushion top
SUB-TOTAL : $ 6,000.00
8.0 - CARPENTRY WORKS AT FOYER
8.1 To supply & fabricate 3 ft full high designed shoes cabinet with laminated finish $660.00
finish and soft-closing hinges
8.2 To supply & fabricate 2 ft designed storage settee with laminated finish, $320.00
8.3 To supply & fabricate 2 ft designed half height feature wall with 04 nos of $680.00
pillars with laminated finish
8.4 To supply & fabricate rear exposed lamination for shoe cabinets and $250.00
feature wall
SUB-TOTAL : $ 1,910.00
9.0 - CARPENTRY WORKS AT MASTER BEDROOM
9.1 To supply & fabricate 100 sqft solid plywood platform with bare finish $1,200.00
(4'' high)
SUB-TOTAL : $ 1,200.00
10.0 - CARPENTRY WORKS AT ROOM 2
10.1 To supply & fabricate 17 ft designed full high wardrobe c/w glass sliding $4,420.00
door, aluminium frame, laminate finish and white internal carcass
10.2 To supply & fabricate 01 nos of mirror set in wardrobe $180.00
SUB-TOTAL : $ 4,600.00
11.0 - CARPENTRY WORKS AT MASTER TOILET
11.1 To supply & fabricate 3 ft suspended vanity cabinet c/w glass door $420.00
aluminium frame & laminate finish
11.2 To supply & install 3 ft solid surface top c/w 2 inch profile $350.00
11.3 To supply & install 1 pc full height x vanity width mirror $180.00
SUB-TOTAL : $ 950.00
12.0 - CARPENTRY WORKS AT KITCHEN
12.1 To supply & fabricate 34.5 ft solid plywood kitchen cabinet c/w laminated $3,795.00
finish,1 dish rack glass door, 4 drawer, 1 cutlery tray, 1 stainless steel dish tray
tray and ABS trimmings for all doors
12.2 To supply & install 17 ft Quartz 20mm thick surface work top with 40mm profile $2,550.00
profile and backsplash
12.3 To supply & install 48 nos of Excel softclosing hinges $240.00
12.4 To supply & install 04 nos of Excel softclosing drawer tracks $200.00
12.5 To supply & install 01 set of Blum softclosing dishrack glass door dampers $220.00
SUB-TOTAL : $ 7,005.00
13.0 - GLASS WORKS
13.1 To supply & install 10mm thick wall to wall tampered glass shower screen at $380.00
at master toilet c/w swing door
13.2 To supply & install 4x7 ft 10mm thick tampered glass swing door at kitchen $560.00
entrance with clear finish
13.3 To supply & install 30 sqft 6mm tempered glass backing between kitchen $660.00
cabinets with choice of painted colours
13.4 To supply & install 30 sqft 6mm designed mirror panel at dining area with $660.00
clear and tinted mirror finish
SUB-TOTAL : $ 2,260.00
TOTAL : $ 31,720.00
ELECTRICAL : $ 1,500.00
LESS : $ 793.00
GRAND TOTAL : $ 32,427.00
Edited by shockwave
SUB-TOTAL : $ -
2.3 To haulage material to unit c/w debris disposal and sand hualage $800.00 Too high
2.4 To supply labour for general cleaning whole house include acid cleaning for $280.00 FOC
2.5 To supply & lay corrugated paper for floor/door protection purposes $180.00 FOC
SUB-TOTAL : $ 2,560.00 - this is expensive
4.0 - CEILING WORKS
board
5.0 - MASONRY WORKS
(4'' high)
SUB-TOTAL : $ 6,000.00 Price too high
feature wall
(4'' high)
SUB-TOTAL : $ 7,005.00 Price too high
13.0 - GLASS WORKS
TOTAL : $ 31,720.00
LESS : $ 793.00
If you need my quote PM me.
Edited by ARl
