ikelvin
My 1St Flat, My 1St Quote , Reasonable ?
:jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop: OMG
My BTO Flat is coming real soon in May, i have received my 1st quotation fr an ID. Since it's my first flat, i have zero experience in reno things and stuff.
Hope some kind bro and sis can gimme some of your precious advices. I have attached the quote below.
A Professional Services
1 Design consultation & site co-ordination FOC
2 Space planning layout plan FOC
3 Design proposal of 3D visual drawing FOC
4 Proposal of materials & color FOC
B Demolition Works
1 To supply labor to hack door size opening on existing wall between Kitchen & Dining
hall 1 lot INC
2 To apply HDB renovation permit for demolition work approval 1 lot FOC
3 PE endorsement and inspection fees (only when HDB request) 1 lot NA
4 Necessary protection works 1 lot INC
5 General clean & washing upon completion 1 lot INC
6 For haulage works bring up wet works materials & clearing debris 1 lot INC
Sub Total B $980.00
C Builder Works
Wet Works
1 To supply & install kitchen cabinet base and shower screen kurb for master toilet
& common toilet c/w matching tiles 1 lot $600.0
2 To supply labor to cement patch up damage wall after hacking new door opening 1 lot $180.0
3 To supply labor to cement plaster smooth existing wall tiles at affected area only
include add on new skirting 1 lot $450.0
4 To supply labor to patch up damage floor tiles kitchen & living after hacking works 1 lot $250.0
Shower Screen & Door
5 To supply & install wall to wall tempered clear glass shower screen c/w 1no
fixed panel and 1no swing panel (include top hung S/S bar support) at master toilet 1 set $580.0
6 To supply & install wall to wall tempered clear glass shower screen c/w 1no
fixed panel and 1no swing panel (include top hung S/S bar support) at common toilet 1 set $580.0
7 To supply & install tempered clear glass sliding door with heavy duty top mount sliding
track at kitchen entrance 1 lot $720.0
Partition Wall & Ceiling Works
8 To supply & install one sided partition box up wall **** hall TV wall recess area 1 lot $440.0
9 To supply & install partition wall to seal up existing kitchen entrance & new sliding door
linder 1 lot $380.0
10 To supply & install plaster false ceiling **** hall entrance, dining area & walkway
corridor outside store room area & L-box at TV area 1 lot $1,500.0
11 To supply & install plaster false ceiling at master bedroom entrance area & L-box
ceiling at window area 1 lot $450.0
12 To supply & install plaster false ceiling at bedroom 2 along wardrobe area 1 lot $250.0
Painting Works
13 To apply selected emulsion paint to paint all ceiling, 3nos bedrooms wall & living
hall & dining wall, store room, service balcony & Kitchen new cement wall
(Nippon 5000 series only) 1 lot $1,550.0
Aluminum Window
14 To supply & install aluminum sliding window comply with HDB requirement approval
at service balcony area (standard design & color) 1 lot $600.0
Bedroom Door
15 To supply & install selected solid designer doors at 3nos bedroom & 2nos toilet doors
c/w level handle lockset & magnetic stopper 1 lot $1,750.0
Sub Total C $10,280.00
D Carpentry
1 To supply & install low & top hung kitchen cabinet c/w swing doors and drawers in
selected laminate and abs edging on door panel finish appx. 29 ft $3,190.0
2 To supply & install selected solid surfacing work top c/w back splash appx. 16 ft $1,120.0
3 To supply labor to install kitchen hob and hood (Hood within cabinet) 1 set FOC
4 To supply & install kitchen dish rack c/w clear glass with frosted film and aluminum
border frame flip up door 1 lot $180.0
5 To supply & install wall mounted timber plywood backing with tempered clear
glass spray paint to white on behind side only at between top & low kitchen cabinet 1 lot $650.0
6 To supply & install appx. 7ft length full ht swing door shoe rack cabinet in selected
laminate & abs edging on door panel finish c/w high tinted mirror at the cabinet width
facing dining side 1 lot $1,810.00
7 To supply & install appx. 6ft length island settee with drawer storage below in selected
laminate & abs edging on drawer door panel finish for dining area (without cushion) 1 lot $780.0
8 To supply & install appx. 8ft length full ht TV wall feature in selected laminate finish.
(For 60inches size TV) 1 lot $1,700.0
9 To supply & install appx. 7ft length suspended TV console c/w drawers & DVD/SCV
storage compartment with flip up tinted black glass panel 1 lot $1,100.0
10 To supply & install appx. 7ft length full ht store room wall feature c/w tick tack door
panel in selected laminate finish 1 lot $1,500.0
11 To supply & install appx. 12.5ft length full ht wardrobe in selected laminate finish c/w
hanging rods, drawers & shelving, include 4nos plywood swing doors & 2nos
aluminum framing with clear mirror finish full size sliding door at bedroom 2 1 lot $3,100.0
12 To supply & install appx. 9ft length settee along master bedroom window area c/w
drawer storage below in selected laminate & abs edging on drawer door panel finish
(without cushion) 1 lot $1,080.0
13 To supply & install 8ft length x 3ft ht wall mounted TV feature & mini console for
DVD/SCV compartment below in selected laminate finish at master bedroom 1 lot $950.0
14 To supply & install suspended vanity swing door cabinet below existing vanity top in
selected laminate with abs edging on door panel finish 1 lot $330.0
15 To supply & install 5ft length x 2.5ft ht top hung mirror swing door cabinet c/w shelf
compartment and with top & bottom lighting compartment at master toilet 1 lot $480.0
16 To supply & install 5ft length x 2.5ft ht top hung mirror swing door cabinet c/w shelf
compartment and with top & bottom lighting compartment at common toilet 1 lot $480.0
17 To supply & install self close hinges for swing door panel on cabinet only 1 lot FOC
Sub Total D $18,450.00
E Plumber
1 To supply labor to install kitchen sink and tap 1 lot $80.0
2 To supply labor to install both toilets accessories 1 lot $100.0
3 To supply labor to install heater tank at common toilet 1 lot $140.0
4 To supply labor to install WC spray beside WC at common & master toilet 1 lot $70.0
5 To supply labor to install rain shower set for master toilet only 1 lot $80.0
Sub Total E $470.00
F Electrical
1 To lay new lighting points at new false ceiling area & toilet mirror area (est.) 24 nos $840.0
2 To supply labor to install light fittings (light fitting by owner)(est.) 25 nos $480.0
3 To lay 13amp power sockets affected by works (est.) 3 nos $210.0
4 To relocate existing SCV point, cat5 data point & 1no double socket **** hall TV
area 1 lot $260.0
5 To relocate existing SCV point, cat5 data point & 1no double socket **** hall TV
area 1 lot $180.0
6 To relocate kitchen/service balony lighting switch to new kitchen entrance area 1 lot $100.0
7 To supply labor to install door bell 1 lot FOC
Sub Total F $2,070.00
GRAND TOTAL AMOUNT IN SGD : $32,250.00
I have no experience about this as i am currently looking for reno contractor.
However, i do find your price reasonably ok because i always have the concept that engaging ID is much exp than a simple contractor job.
Btw, how many rooms r yrs?
Edited by Sunshine3
