Hello to all Renotalkers! Greeting from a girl who simply love home decoration and renovation, learn and share some DIY tips with the others. Having read on so many sharing from other Renotalkers, I decided to share some of my little tips in this t-blogs as well. Hope everyone will enjoy reading it and please do feel free to share you ideas / thoughts here too! :)
Here come's the first piece of my sharing...
<Mirror mirror on the wall...>
Mirrors are some of the most versatile items used in interior decorating, and when they are employed tastefully and creatively they can really transform the appearance of a room. There is a wide variety of mirrors of all shapes and sizes, so you will have choice whatever your budget and preferred aesthetic. With a little ingenuity, there are a number of ways you can use mirrors to give your house a new look.
Enlarge a Room
A wide mirror can work wonders to enhance the appearance of a room to make it appear more spacious. Hang a wide mirror high up on the wall by the dining table or in the living room, reflecting the interior and making it appear twice as large as it really is.
Soften Corners
If you have sharp corners in the house, whether due to the shape of your rooms or angular furniture, mirrors can help to soften them. For instance, positioning a round mirror above an angular coffee table can soften otherwise harsh lines considerably.
Underscore Your Theme
Mirrors come in all sorts of frames, and well-chosen frames can help to underscore your theme and create the atmosphere you are trying to achieve. If you want your interior to look rustic and inviting, mirrors in wooden frames can add to the warmth of your colour palette. You can even purchase or make your own frames to house your mirrors in.
Experiment with Shapes
Since mirrors come in every conceivable shape, from round or oval to angular or oblong, you can experiment with shapes to enhance the appearance of your space. For instance, if your space is very modern, a combination of oblong-shaped mirrors can contribute to the futuristic atmosphere.
Combine Several Mirrors
Use several mirrors in tandem to transform your wall space. Just as picture frames can be combined to produce elaborate wall-scapes, several mirrors can be grouped together to form a reflective collage.
Hang Mirrors Alongside Picture Frames
If you already have picture frames on the walls, mirrors can be interspersed amongst them to fill up space and to add completeness to an existing collage of picture frames. Match the frames of your mirror with your picture frames so they blend in seamlessly.
Use Reflections Strategically
Your mirrors should not be thought of merely as ornaments for the walls. You should also consider what is being reflected in the glass and use this to your advantage when positioning your mirrors. For instance, if your windows afford beautiful views, position your mirrors so they reflect the scenery. If you are fond of burning candles on a sideboard, a mirror placed just behind the candles can help to generate an evocative atmosphere. A mirror at the end of a hall can give the hallway a more extended feel.
Use Other Reflective Items
Creativity is key when decorating an interior, and there is a whole host of other items that can function as decorative mirrors. Sheets of aluminium and other metals are reflective and can produce interesting effects when used in interior decorating.
Mirrors are extremely versatile and can be adapted to any kind of interior. When decorating your interior, using mirrors creatively can be the step that enhances and completes the look of your home.
--- End ---
You know what? Some of my blog posts are now featured on Gumtree blog too!! So pls kindly come and support me!! :yamseng:
