Pls provide quote for Daikin and Mitsubishi Electric (2 ticks/5 ticks) System 4.
3 bedroom (9kBTU) and living room (18kBTU)
HDB 4 room with aircon ledge
Thanks,
WT
  • Replies 1.1k
  • Views 188k
  • AirconBestValue
    AirconBestValue
  • AirconBestValue
    AirconBestValue
  • AirconBestValue
    AirconBestValue
Posted Images
Can pls quote:
Supply and install Mitsubishi Electric Inverter R410.
Outdoor model: MXY-3A28VA (1 unit)
Indoor model: MSY-GE10VA (2 units)
                         : MSY-GE18VA (1 unit)
On 4/21/2016 at 2:46 PM, alterpath said:
Hi there,
May I request a quote for the following
Brand New Installation for HDB 3rm
Daikin Inverter Aircon System 2
3MKS50FSG
FTKS25DVM x 2 (9,000 BTU)
Mitsubishi Heavy Inverter Aircon System 2
SCM45ZJ-S1
SRK25ZMA-S1 x 2 (9,000 BTU)
Will be great if I can have an close estimate to the final cost. Thank you.
Regards,
Michelle
On 4/24/2016 at 5:38 PM, cinnamoroll said:
Please quote me Mitsubishi Inverter Sys 3. MXY3A28VA (CU 25KBTU), 3 x MSYGE10VA (FCU 9K BTU).
HDB.
Regards,
Michelle
On 4/24/2016 at 0:52 AM, WTLIM said:
Thanks,
WT
Regards,
Michelle
On 4/24/2016 at 1:21 AM, MetalTab said:
Can pls quote:
Regards,
Michelle
Dear all Renotalk Bro & Sis,
At the same time, i would like to inform all our customer we have expand our business for electrical work and CCTV installation, please let us know if you need a quote, we will create a combo package for your :)
Warmest Regards,
Michelle
8 minutes ago, lifeisfullofupndown said:
Hi, can you PM me the price of Daikin 3 ticks system 3? I need 9k BTU for all.
Regards,
Michelle
Can I have a quote  for Mitsubishi and Daikin system 4?
For Mitsubishi :MXY-4A28VA
3 x 9k btu
1 x 24k btu
HDB
Edited by brokenonends
Please quote Starmex, Daikin, S3, 9k btu. HDB. Thanks.
Pls quote for Toshiba system 5, and if it's feasible for a old 5 room flat with one compressor
Hi, can you quote me the prices for Panasonic, Mitsubishi and Daikin system 4 inverter?
3 x 9k btu
1 x 24k btu
HDB
Do you do installation of new Fancoil unit to a bedroom only using existing compressor?
Hi, can you please quote me for the following?
Mitsubishi Starmex Model: MXY-4A28VA / MSY-GE10VA X3 + MSY-GE24VA (2 ticks model)
Requirements:
- materials: G22 copper coil, 1/2" Armaflex class "0" insulation, 16mm PVC drain pipe with armaflex insulation, 3 core 40 Keystone control wire
- others: 2 trips installation, dismantling & disposing of existing system 3 air-cons
- work with my ID on the required works
Please also quote me for the above requirements based on the latest 5 ticks model as well.
