4 Room Standard Bto Quotation By Id
Hi all, I have just collected my keys 2 weeks ago and having no experience in renovation, would like to ask if the following quotation is reasonable? Please highlight which items are overpriced if possible. Thanks in advance!
ADDITIONAL WORKS
DEMOLITION WORKS Unit Amount Total
Hack off 5.5 ft half wall at kitchen------------------------------------------------------------------------------------------------------------------------- $250
MASONRY WORKS (tiles at $3.5 or below)
Supply and construct kitchen cabinet base with side tile finishing ------------------------------------------------------------------------------- $450
Supply and lay 600 x 600 homogenous floor tile for living, dining, corridor walkway ---------------345-----------------7-----------------$2,415.00
Supply and lay 100% waterproof vinyl flooring for master room (cement screed by HDB) -------184-----------------5.5---------------$1,012.00
Supply and lay 100% waterproof vinyl flooring for bedroom 2 (cement screed by HDB) ---- -----121-----------------5.5---------------$665.50
Supply and lay 100% waterproof vinyl flooring for bedroom 3 (cement screed by HDB) ----------117-----------------5.5---------------$643.50
Supply and install 4" parquet skirting for living, dining, corridor, bedroom 2, bedroom 3----------199-----------------5.5---------------$1,094.50
Supply and apply 3 in 1 prepack cement screed for whole house (hdb required) -------------------------------------------------------------$1,035.00
Touch up and make good kitchen hacked wall (plaster and replace affected tile)-------------------------------------------------------------$280.00
CARPENTRY WORKS (solid plywood with internal white PVC, BLUM hinge included) Kitchen
Design and fabricate 7 ft kitchen top cabinet in laminate finish---------------------------------------------7-------------------120---------------$840
Design and fabricate 12 ft kitchen bottom cabinet in laminate finish (both side)----------------------12-------------------120---------------$1,440.00
Supply and install 12 ft crystal quartz top with backsplash----------------------------------------------- --12------------------120---------------$1,440.00
Supply and install tempered glass backing in between kitchen cabinet---------------------------------------------------------------------------$450.00
Design and fabricate 2 ft tall unit in laminate finish-----------------------------------------------------------------------------------------------------$720.00
Living
Design and fabricate 10 ft full height tv feature wall in laminate finish (partial glass finish)---------10--------------------350-------------$3,500.00
Design and fabricate 8 ft suspended tv console in laminate finish-----------------------------------------8---------------------130-------------$1,040.00
Design and fabricate 3 ft full height shoe cabinet in laminate finish----------------------------------------3---------------------260-------------$780.00
Design and fabricate 3 ft full height glass display unit---------------------------------------------------------3---------------------450-------------$1,350.00
Supply and install STACO wall panel **** area (brick type)-------------------------------------------------------------------------------------------$1,850.00
Supply and install full height clear mirror at dining area------------------------------------------------------------------------------------------------$480.00
Master Bedroom
Design and fabricate 11 ft full height L-shaped casement wardrobe in laminate finish---------------11--------------------280-------------$3,080.00
: with internal small dressing table
Design and fabricate 5 ft full height simple tv feature wall in laminate finish (with cove holder)-----5---------------------180-------------$900.00
Design and fabricate 5 ft suspended tv console in laminate finish------------------------------------------5---------------------130--------------$650.00
Bedroom 2
Design and fabricate 5 ft full height casement wardrobe in laminate finish-------------------------------5----------------------240-------------$1,200.00
PLUMBING WORKS
Supply and modify hot & cold water pipe for city gas heater at service yard-----------------------------------------------------------------------$180.00
Supply labour to install 1 nos kitchen sink and tap--------------------------------------------------------------------------------------------------------$120.00
Supply labour to install toilet accessories for both toilet --------------------------------------------------------------------------------------------------FOC
ALUMINIUM / GLASS WORKS
Supply and install aluminium 3 tracks sliding window at service yard-------------------------------------------------------------------------------$620.00
Supply and install AUSTSCREEN BUMPFREE tempered sliding shower screen for master bathroom-----------------------------------$640.00
Supply and install AUSTSCREEN BUMPFREE tempered sliding shower screen for common bathroom---------------------------------$640.00
CEILING WORKS
Supply and construct 450mm L-Box with cove light holder for living area--------------------------------------------------------------------------$550.00
Supply and construct false ceiling for dining area---------------------------------------------------------------------------------------------------------$520.00
Supply and box up aircon trunking at corridor walkway--------------------------------------------------------------------------------------------------KIV
PAINTING WORKS
Supply and paint whole house wall with Nippon Vinilex 5000 (4 colors +1 standard ceiling white)------------------------------------------$1,200.00
GENERAL WORKS
Supply haulage and clear whole house debris------------------------------------------------------------------------------------------------------------$450.00
Supply and lay cardboard for floor protection--------------------------------------------------------------------------------------------------------------$300.00
Acid washing upon completion (2 times)--------------------------------------------------------------------------------------------------------------------$300.00
TOTAL : 33,085.50
Edited by sonic84
