Is The Reasonable Quote For Approx 800 Sqft Resale 4 Room?
Summary:
- basically hacking all floors in the house, replace with homogenous floor tiles in kitchen, 2 toilets and living area
- hack existing carpentry
- replace all wall tiles in 2 toilets
- no wall tiles in kitchen
- 1 x 2 door tall cabinet
- vinyl flooring in 3 bedrooms
- kitchen top and bottom cabinet on 1 longest wall (1 side)
- kitchen bottom cabinet only on 1 short wall only
1. Hacking and demolition work (inclusive of clearing debris and haulage) $ 4,800.00
  • Hack off existing kitchen wall and floor tiles.
  • Hack off existing common toilet wall and floor tiles
  • Hack off existing living/dining floor tiles.
  • Hack off existing bedrooms floor.
  • Hack off existing master bathroom wall and floor tiles.
  • Dismantle existing kitchen cabinet.
  • Dismantle existing tv console and box up at bomb shelther.
  • Dismantle existing cabinetary in bedrooms.
  • Dismantle existing false ceiling in the house.
  • Dismantle existing window grilles.
2. Mansory works
Supply materials and tools to lay new non-slip homogeneous floor tiles for kitchen 125 sqft @ 11.00 psf - $1,375
Supply materials and tools to lay skim coat for kitchen wall. 400 sqft @ $5 psf - $2,000
Supply materials and tools to lay new non-slip homogeneous floor tiles for common toilet - $680
Supply materials and tools to lay new ceramic wall tiles for common toilet. 250 sqft @ 13.00 psf - $3,250
Supply materials and tools to lay new homogeneous floor tiles for living/dining c/w tile skirting 285 sqft @ $ 11.00 psf - $3,135
Supply materials and tools to lay new non-slip homogeneous floor tiles for master toilet - $680
Supply materials and tools to lay cement screeding for vinyl floor tiles at 3 bedrooms. 310 sqft @ 5.50 psf - $1,705
Supply materials and tools to install vinyl floor tiles for 3 bedrooms with timber skirting. 310 sqft @ $ 6.20 psf - $1,922
Supply materials and labour to lay waterproof membrane for common and master toilet floor and shower area wall up to 1.5m height. - $400
Supply materials and tools to construct cement base for kitchen cabinet with tile skirting. - $200
Supply materials and tools to lay new ceramic wall tiles for master toilet. 240 sqft @ $ 13.00 psf - $ 3,120
3. Carpentry works
Design and fabricate bottom kitchen cabinet in laminate finish with necessary ironmongeries. 5.5 ft @ $ 130.00 pf - $ 715
Supply and install iQuartz worktop for bottom cabinet at stove area with 50mm skirting. 5.5 ft @ $ 140.00 pf - $ 770
Design and fabricate bottom kitchen cabinet at sink area in laminate finish with necessary ironmongeries. 9 ft @ $ 130.00 pf - $ 1,170
Design and fabricate hanging kitchen cabinet with necessary ironmongeries, inclusive of cabinet above fridge. 12 ft @ $ 220.00 pf - $ 2,640
Supply and install iQuartz worktop for bottom cabinet at sink area with 50mm skirting. 9 ft @ $ 140.00 pf - $1,260
Design and fabricate full height shoe cabinet with open shelf in laminate finish. 3 ft @ 280.00 pf - $ 840
Supply and install backing between top and bottom cabinet using Ceral panel or white painted glass. 14.5 ft @ $ 60.00 pf - $ 870
Supply and install 30kg full extension blumotion drawer runner. 4 qty @ $ 50.00 each - FOC
Supply and install HK lift up system for flip up door. 3 qty @ $ 100.00 each - FOC
4. Door/Glass works
Supply and install aluminium frame door and door frame with frosted glass inset for toilet. 2 @ $ 550.00 each - $ 1,100.00
5. Plumbing work
Supply labour and materials to lay new stainless steel cold water pipe for whole house and hot water pipe for 2 toilets, inclusive of conceal works. - $ 950.00
Supply labour to install the followings: (sanitary items supply by owner)
  • 2 Toilet bowl - $ 180.00
  • 2 Set Basin and tap, inclusive of discharge pipes - $ 240.00
  • 2 Set Shower head and tap $ 120.00
  • 1 Storage heater - $ 240
  • 2 Bidet spray - $ 100.00
  • 2 x Toilet accessories - $ 100.00
  • Kitchen sink and tap, inclusive of discharge pipes $ 120.00
6. Misc
Painting for whole house wall and ceiling using Nippon premium emulsion paint (5 colours). - $ 1,600
Supply and lay cardboard for floor covering after tiling works. $ 280.00
General cleaning and chemical wash after renovation works. $ 380.00
Supply and install exhaust fan for 2 toilet, inclusive of changing existing louvre window to fixed panel $ 560.00
Total: $37,502, after one time discount total is $36,000
Optional: Electrical works
New lighting point @ $ 38.00 each
New 13Amp single power point @ $ 60.00 each
New 13Amp double power point @ $ 70.00 each
Cooker hood point with switch @ $ 50.00 each
Oven point @ $ 100.00 each
Data point cat 5e @ $ 120.00 each
Supply labour to install light fitting @ $ 12.00 each
Supply labour to install normal hanging light @ $ 50.00 each
Edited by fondue_
