wycklk
Kitchen Carpentry And Solid Surface Top Contacts
Dear all,
I've researched the threads discussed earlier and googled direct factory carpenters. The lowest I can find now is about $110 per foot run with standard laminate for kitchen cabinet.
Also I need contractors that can quote contractor price for solid surface top brands like Coran, LG Hi-Macs, Samsung Staron. I was told solid surface top is no longer popular and being phased out. I called the distributor for LG Hi-Macs, and was given a price that is higher than Coran :-)
Kindly PM me if you have good contacts to share.
Thank you very much.
Just to share with you not to use Singapore Carpentry which was run by a designer call Ernest Tan. He actually sub-out all his work to other small carpenter. Bad workmanship, incomplete work and he hardly response to message and do not pick up phone but only know how to chase for payment.
yup best bet is choose a contractor with their our manpower to do the jobs.
Good is complete job in time or faster, cheaper, deflects can go direct them to retify, things not pushing around also, rectification duration faster
