Water Pressure Low
I have issue on my both toilets where the water pressure very low especially my Master Bedroom Toilet.
It will be even worst if someone uses another toilet at the same time and will experience even lower pressure.
I'm staying at the highest floor and I'm using a instant water heater.
Anyone, who has a rectification to this issue that I am currently facing, pls advice.
Cheers!
You should check if the main water valve (outside your house in the utility riser) is fully open.
If it is fully open and still the same problem, ask your neighbors if they have the same problem.
