Chawn Phats
Need Help to review 5i Resale Quote :) 1st Time Home Owner
  Design Works
  Space planning & Optimization
  Project planning, Supervision & Management
  All Necessary Authority permit Application
A Living area
1 Demolition Works
1.1 Supply labour & tools to demolition built-in furnitures   $ 450.00
2 Flooring Work .
2.1 Supply labour and materia to fill new grouting for floor tiles   $ 600.00
B Kitchen area
1 Demolition Works
1.1 Supply labour & tools to hack off existing wall tiles, flooring & skirting   $ 700.00
1.2 Supply labour & tools to dismantle existing kitchen top cabinet .   $ 150.00
2 Flooring Work .
2.1 Supply labour and materials to lay selected designer homogeneous floor tiles $ 1,200.00
  includes cement screeding, chemical adhesive cement w/ skirting .
  (Tiles @ $3.00)
2.2 Supply labour & materials to provide HDB regulated water proofing membrane $ 300.00
  layer using quic-seal 104 chemical & non-shrink screed .
3 Wall Work .
3.1 Supply labour and materials to plaster smooth kitchen wall   $ 1,000.00
4 Carpentry work.
4.1 Design, fabricate & install (01) unit top kitchen cabinet .   $ 1,490.00
  *3D computerized perspective drawing provided
  Top cabinet Measurement: L 3400mm x D 300mm x Ht 900mm
Materials: Solid plywood c/w high pressure laminate finishes & ABS edging door
  internal carcass in white PVC finishes .
5 Glass work
5.1 Supply  & install (01) unit 6mm thk tempered glass backing for kitchen   $ 400.00
  in spray paint finish
  Measurement: L 3400mm x Ht 600mm
C COMMON BATHROOM
1 Demolition Works
1.1 Supply labour & tools to hack off existing wall & floor tiles. $ 500.00
2 Masonry Works
2.1 Supply labour & materials to provide HDB regulated water proofing membrane $ 400.00
2.2 Supply labour & materials to lay selected designer matt surfaced $ 500.00
  homogeneous floor tiles including cement, chemical adhesive cement,
  chemical strengthened bonding(W1) & colour grouting for tiles gap.
  (Tiles @ $3.00)
3 Wall Work .
3.1 Supply and lay selected designer homogeneous wall tiles $ 2,500.00
  includes cement screeding, chemical adhesive cement, chemical
  strengthened bonding membrane ( W.1 ), grouting for tiles gap.
  (Tiles @ $3.00)
4 Plumbing Works
4.1 Supply labour & materials to lay conceal PVC drainage  piping for wash basin & $ 150.00
  shower area.
4.2 Supply labour & materials to provide installation of:-
  - toilet bowl x 01 $ 110.00
  - wash basin x 01 $ 60.00
  - gallon heater x 01 $ 120.00
  - toilet accessories x 01 set $ 50.00
5 Doors & Window Work
5.1 Supply & install (01) unit white powder coated aluminium Naco window $ 180.00
5.2 Design, fabricate & install (01) unit PD door for toilet $ 500.00
5.3 Design, fabricate & install (01) unit 10mm tempered glass frameless fix panel $ 240.00
  to separate toilet bowl & shower
  Measurement: L 600mm x Ht 1900mm
D MASTER BATHROOM
1 Demolition Works
2 Masonry Works
  (Tiles @ $3.00)
3 Wall Work .
  (Tiles @ $3.00)
3.2 Supply labour and materials to construct 2 inc shower kerb $ 200.00
4 Plumbing Works
  shower area.
5 Carpentry Works
5.1 Design, fabricate & install suspendered vanity using solid plywood c/w high pressure $ 300.00
laminate finish, ABS edging doors & internal carcass in white PVC finishes
  Measurement: L 600mm x D 550mm
  Measurement :
5.2 Supply labour & material to install solid surface work-top   $ 200.00
  Measurement: L 550mm x D 550mm
  Model :
6 Doors & Window work
6.1 Design, fabricate & install (01) unit PD door for toilet   $ 500.00
6.2 Design, fabricate & install (01) unit 10mm tempered glass sliding door w/ fix panel $ 650.00
  shower screen
  Approx. Measurement: L 1300mm x Ht 1900mm
6.3 Supply & install (01) unit white powder coated aluminium lourve window $ 180.00
E Painting work
1 Supply labour & materials to paint whole house 4+1 colour   $ 1,500.00
F Miscellaneous/ Other works
1 Supply haulage to building materials & renovations debris   FOC
2 Supply labour to disposal of construction debris to dumping ground FOC
3 Supply labour & materials to Lay corrugated protective sheet to all  affected area $ 800.00
4 Supply labour for washing for entire unit   $ 800.00
    Sub Total: $ 21,000.00
Quote
Your above works seems very expensive...
Can get cheaper. Got a contractor to recommend.
my house was done by golden bricks building contractor located at hougang ave 1.. their service was pretty good and boss was accomodating
no GST and the best part is the price is reasonable... heard they got their own in house carpentry.
their contact for office is 6281 0091/5736. u can pm me for boss's direct hp too :)
