emm06
Quote from contractor - Reasonable?
On 15/08/2016 at 10:45 AM, emm06 said:
I'm new here, and would need advise on the below quote. I'm not too sure what my contractor quoted is reasonable, as we were quoted different price during site visit vs actual quote? The different is about 4K , is this normal?
CARPENTRY WORKS:
Re: Install laminated finished swing door cupboard with door panel abs trimming.
Internal cupboard white pvc plywood board. Build in height 8ft.
Re: All sink, mixer, cooker hob, hood, accessories fitting will be provide by owner.
01) Install top 8.5ft and bottom 6ft one roll only kitchen cabinet. $1,920/-
02) Install bottom cupboard 5.5ft one roll only. $1,080/-
03) Install solid surface kitchen work top. Length 6ft and 5.5ft. $1,020/-
04) Construct 50mm thick kitchen floor cupboard base and fridge tiling base. $650/-
05) Install wall tempered glass between top & bottom kitchen cabinet. Size: L180cm x H50cm $750/-
06) Install master bedroom full high aluminium frame sliding door wardrobe. Length 140cm. $1,850/-
07 a) Install joint wardrobe one side full high swing door with bedside table opening. L40cm. $680/-
b) Install bedhead plywood board with one side bedside table opening and low drawer.
Total length estimated 190cm x H110cm. $1,370/-
08 a) Install wall hang vanity bottom cupboard with solid surface top. Length 70cm. $560/-
b) Remove existing basin, s/s inlet and discharge pipes alteration. $160/-
09) Floor cardboard protection covering at hall and bedroom. $150/-
SHOWER SCREEN AND GLASS DOOR;
10) Install one set clear frameless tempered glass shower screen at master bathroom.
Size approx; L155cm x H190cm x 10mm thick.(one fixed one swing panel w/o top bar) $840/-
11) Construct 50mm thick floor shower tiling kerb. $190/-
12 a) Install one number frameless clear tempered glass swing door at kitchen. $790/-
b) Reposition existing kitchen light gang switch with wall tile replace. $250/-
ALUMINIUM WINDOW GRILLE;
13) Install 4 panel 2 rail aluminium sliding window with tined black glass at service balcony. $590/-
14) Install n.a.aluminium 3nos. sliding grilles **** hall and 2 bedroom. $780/-
PLUMBING WORKS;
Re: All sanitary ware, heater or accessories fitting will be provide by owner.
15) Supply labour only to install 1 number storage water heater at bathroom. $250/-
16) Supply labour only to install kitchen sink tap and upvc drainage pipe. $160/-
17) Supply labour, tools to install bathroom wall accessories fitting. $190/-
Painting works;
18) To paint whole ceiling ICI maxilite emulsion white. All walls pentalite emulsion finished. $1,200/-
Included metal door frame and store/CD door gloss paint.
Re: To paint over existing timber door gloss paint finished. 2nos. Bedroom door.
2nos. toilet door and 2 leave main door. Prices $290/-
ELECTRICAL WORKS;
Re: All lights, fan will be provide by owner. Any gang or socket alteration will be charge extra.
19) Supply labour to install ceiling fan with existing light point shift. $220/-
20) To cut hack alter existing concrete ceiling lighting point with additional gang switch
control **** ding area.(2 number) $500/-
21) Install alteration 1x13amp socket, relocate extg. socket & phone point at m/bedroom. $190/-
22) Supply labour to install ceiling lights and false ceiling down lights. Estimated 13nos. $460/-
FALSE CEILING BOARD;
23) Install 3 side L box light holder **** area. $1,180/-
24) Install false ceiling board at dining area. $720/-
Total: $18,700/-
Thanks in advance. :)
Hope u not yet sign. Got to agree, is on the high side... look around more bah. My also not so x.
On ‎15‎/‎8‎/‎2016 at 10:45 AM, emm06 said:
CARPENTRY WORKS:
PLUMBING WORKS;
Painting works;
ELECTRICAL WORKS;
Total: $18,700/-
can share contact details of your contractors please? Thanks!
my email address : mnemosyne@live.com.sg.
On 8/16/2016 at 10:59 AM, emm06 said:
@tanks we felt that too... now we are looking for another quote.
@jordanchang Hi, thanks could you pm me the contact of the contractor. :)
On 8/16/2016 at 10:53 AM, jordonchong said:
Hi emm06,
Yeaa, they are all over price. More like a ID than a contractor. If you are interested in finding more contractor, I can pm you my recommended contractor with 30+ years family run renovation company. HDB licensed as well
Can you share the contractor contact?
my email is wlimyuh@gmail.com.
Thanks
