Need help on Quotation - resale flat 5room
Dear Master,
This is my first time to renovate the house. Please advise whether the below quotation received is reasonable.
Thank you
A) Hacking & Dismantlin Works
Hack off existing wall tiles and floor tiles including dismantling existing kitchen cabinets and sink cabinet and base and toilet bowl and wash basin at kitchen and 2 nos toilets                  1,900.00
Demolition off existing brick wall and aluminum sliding door                     950.00
Dismantle existing laminated flooring with skirting and cabinet and furniture and wardrobe                     950.00
B) Living , dining , balcony & 3 nos Bedrooms
Supply & overlay homogeneous floor tile with skirting **** , dining , balcony and 3 nos bedrooms (not exceeding $4.00 sq ft)                  8,100.00
SuppIy and box-up cement board partition wall for balcony main pipe Supply and replace I nos window grille lock set and stainless steel lock set and metal gate stopper                     505.00
Supply and replace wooden classic door for 3 nos bedrooms                     540.00
C) Kitchen
Supply & overlay homogeneous floor tile at kitchen ( not exceeding $4.00 sq ft)                  1,450.00
To construct 50mm kitchen cabinet ,base fridge base, washing machine base for Kitchen cabinet                     450.00
Supply & lay ceramic wall tiles with 3-in-l wall cement for Kitchen  ( not exceeding $4.00 sq ft)                  4,500.00
To design & fabricate 34 feet Top & Bottom Kitchen cabinet with solid plywood in laminated finishing with soft closing door( include box up kitchen main pipe )                  4,320.00
To supply, fabricate & install 1 7 feet granite top with backsplash & front profile for Kitchen cabinet                  1,700.00
Supply & install inlet & outlet piping for kitchen sink & washing machine                     160.00
Supply & install stainless steel water piping for Kitchen                     380.00
Supply and install aluminum PD door at kitchen entrance (1600mm X 2150mm)                     950.00
D) Master Toilet & Common Toilet
Supply & lay homogeneous floor tiles with waterproofing & 3-in-l floor screeding for 2 Toilets (600mm x 150mm, tiles not exceeding $4.00 sq ft)                  1,300.00
To provide waterproof treatment flooring for 2 toilets                     500.00
Supply & lay ceramic wall tiles with 3-in-l wall cement screeding to full height for 2 Toilets (600mm x 150mm, tiles not exceeding $4.00 sq ft)                  4,500.00
Supply & install stainless steel piping cool and hot water pipe for shower at 2 Toilets                     600.00
Installation of 2 nos of toilet bowl, 2 nos ofwash basin, storage heater & bathroom accessories, etc. for 2 Toilets                     550.00
Supply & install inlet & outlet piping for 2 nos toilets wash basin                     160.00
Supply & install 2 nos of PD door for 2 Toilets                     640.00
Supply and install 1 Omm temper glass sliding door shower screen for master toilet                     580.00
Supply and construct vanity support with granite top  for master toilet (1500mm X 600mm)                  1,500.00
E) Electrical Works
Hack and relocate conceal lighting point 4 nos and socket and make good plaster **** hall                     250.00
F) Miscellaneous Items
Clearing of debris & protection covering for flooring                     550.00
Acid washing & general cleaning for whole house                     250.00
To rovide painting service for whole house & 3 nos bedroom door , store romm , main door                  1,650.00
Discount               (1,885.00)
Total amount               38,000.00
14 minutes ago, Chong Xun said:
Dear Master,
Thank you
C) Kitchen
E) Electrical Works
Discount               (1,885.00)
it could be lesser? try nego with your contractor
  • 1 month later...
After decided with this renovation, the following pictures of my house near completion renovation
Congrats, looks good!
Can share some before renovation photos for comparison?
Managed to clean part of the house, living room, study room and kitchen for my furnishing to come in :)
Edited by Chong Xun
