Hi everyone, I am on the verge of signing my contract with my contractor and i would be choosing the tile at the same time before i sign.
Can the kind souls out there pls help me look at my price ?
Direct cost is he told me to pay his contractor myself but he will help me co-ordinate. This quotation is not the cheapest i got, but we like his attitude and also commitments.
Total will be about $45k.... but we are doing up the whole place so i need you guys to help me see if it is overprice.
thank you
S/N Description of Work Qty Price
1) Hacking works
a Remove floor tiles and skirting for whole house.
b Remove wall tiles at kitchen and both bathrooms.
c Remove bathroom accesorries,sinks and pedestal pans.
d Hack new doorway at master bathroom.
e Remove existing kitchen cabinet and sink support.
f Remove service balcony door and frame.
g Remove platform at master and living area.
h Remove cabinet **** and master room.
i Remove all cornices and false ceiling.
j Haulage and clear debris for entire project. $ 3,200.00
2) Wet Works
a Construct 50mm cement mortar base for kitchen cabinet with tiles skirting. $ 240.00
b Supply and lay homogenous floor tiles at common bathroom.(Tiles up to $3psf)) $ 330.00
c Supply and lay homogenous floor tiles at master bathroom.(Tiles up to $3psf) $ 360.00
d Supply and lay homogenous floor tiles at kitchen and service balcony. (Tiles up to $3psf) $ 950.00
e Construct shower kerb/drop for master bathroom. $ 60.00
f Supply and lay HDB specified and approved waterproofing screed and membrane at both bathrooms, service balcony and kitchen. $ 380.00
g Supply and lay full height wall tiles at common bathroom.(Tiles up to $2psf) 210sf $ 1,260.00
h Supply and lay full height wall tiles at masterbathroom.(Tiles up to $2psf) 200sf $ 1,200.00
i Supply and lay full height wall tiles at kitchen .Area behind cabinet to be screeded(Tiles up to $2psf) 380sf $ 2,280.00
j Supply and lay homogenous flooring ****,dining,store and 3 bedrooms.(Tiles up to @$3psf)c/w matching skirting.(Skirting using same tiles) 948sf $ 6,067.00
k Supply and lay pebblewash and timber floor tiles at balcony.App 50/50 (Tiles up to $2.80psf) $ 450.00
l Supply and seal up existing master bathroom doorway with hollow blocks.c/w with smooth rendering one side. $ 160.00
3) Plumbing Works
a Supply labour to install two units pedestal pan. 2 sets $ 140.00
b Supply labour to install kitchen sink and tap. $ 60.00
c Supply and re-run stainless steel piping for kitchen and bathrooms.(cold water only) $ 550.00
d Supply labour to install 2 unit wash basin and tap.Outlet inclusive. 2 sets $ 120.00
e Supply labour to install bathroom accessories and spray jets. 2 sets F.O.C
f Supply and install washing machine and sink outlet. F.O.C
4) Ceiling works
a Supply and install false ceiling for 3 bedrooms,living and dining area. 925sf $ 2,220.00
b Supply and install gypsum partition to level wall and box up sewage down pipe **** and balcony area. $ 380.00
c Seal window opening at masterbedroom. F.O.C
5) Other works
a Supply and install 10mm tempered glass swing door shower screen(1 fixed panel and 1 swing door) at master bathroom.c/w chrome towel handle. $ 400.00
b Supply and install frosted design 10mm tempered glass swing door at master bathroom entrance c/w stainless steel handle and lock. $ 400.00
c Supply and install 10mm tempered frosted design glass fixed panel with sliding door at kitchen entrance.c/w stainless steel handle. $ 1,250.00
d Supply and install 3 sets White powder coated toilet bifold door.c/w PVC panels. 2 sets $ 360.00
e Acid wash/General cleaning. F.O.C
f Supply and install 3 unit lever locksets for 3 bedroom doors. 3 sets $ 120.00
g Supply,stain and varnish 3 bedroom doors.(Staining to walnut,need more layer of paint) 3 units $ 195.00
h Supply and install white powder coated aluminium sliding windows for masterbedroom, 2 bedrooms and service balcony.c/w Blue glass. 117sf $ 1,521.00
i Supply and install white powder coated aluminium casement window at private balcony.c/w Blue glass. 40sf $ 680.00
j Supply and install white powder coated aluminium sliding windows grilles for 3 bedrooms,private and service balcony.(window grilles panels to follow window panels) 157sf $ 1,020.00
k Supply and install powder coated sliding window at service balcony opening. $ 80.00
l Supply and install white powder coated adjustable lourvers at master bathroom. $ 180.00
6) Carpentry Works
a Supply and install solid plywood L-shape kitchen cabinet as per design.c/w ABS trimming doors,2 units alumix glass doors,stainless steel dish rack and 4 set Blum self retractable drawer tracks and soft closing hinges.Inclusive accessable panel to stainless steel pipe joints. 34ft $ 3,570.00
b Supply and install solid surface kitchen work top.@$63pfr (Granite 40mm profile drop@$110) 20ft $ 1,260.00
c Supply and install horizontal and vertical box up for sewage pipes at service balcony. F.O.C
d Supply and install Lshape glass backing at between top and bottom cabinet. $ 400.00
e Supply and install laminated wall hung vanity base cabinet at master bathroom.c/w alumix glass door and wall to wall mirror.c/w glass side panel and bottom arcylic to prevent water splashing. 5ft $ 700.00
f Supply and install solid surface vanity top at master bathroom. 5ft $ 315.00
g Supply and install alumix pole system wardrobe in alumix eco glass sliding doors at master bedroom.c/w side partition. 7ft $ 1,785.00
h Supply and install alumix pole system wardrobe in alumix eco glass sliding doors at bedroom 1.c/w side partition. 6ft $ 1,530.00
i Supply and install alumix pole system wardrobe in alumix eco glass sliding doors at bedroom 2.c/w side partition. 6ft $ 1,530.00
j Supply and install laminated build in base cabinet under window recess area for 3 bedrooms.c/w internal back and side ply backing and ABS doors. $ 1,580.00
k Supply and install frosted design glass swing door at store room.c/w stainless steel handle. $ 400.00
l Supply and install full height wood strip divider with display rectangle box in varnishing finishes.Length 800mm.Optional@ $500. Varnish means not using laminate but uses either solid wood or veneer wood. $ 500.00
m Supply and install TV console with backing in laminated finishing.c/w stainless steel leg. Per feet run @$180 11ft $ 1,980.00
n Supply and install width2ft by height7ft laminated and glass display cabinet **** area.Optional@$600 $ 600.00
E.& O.E.
$ 42,763.00
$ 42,580.00
Note: Payment terms
10%-Upon confirmation signing of contract
40 %-Upon hacking and delivery of tiles and building materials
40%-Upon carpentry delivery and installation.
10%-Upon Handover
All diemension is subjected to actual site measurment.
All carpentry internal in white PVC unless stated otherwise.
No GST for the above amount.
Inclusive of co-ordination works for direct cost items.
Inclusive of necessary permit application.
Inclusive delivery of all material to door step.
Direct cost.
a Supply labour to paint whole unit with ICI Dulux/Nippon paint.Inclusive all sewage pipe,doors and frames and main gate.(Minimum 2 coats based on wall condition.) $ 650.00
b Paint cost. $ 350.00
c Supply and provide wall plastering for whole unit. $ 1,300.00
Total: $ 2,300.00
Grand Total $2.3K + $42.5 ~ $45k
Edited by weevenge
If i did not guess it wrong your contractor should be in carpentry trade. His price in all the carpentry works is much more higher.
The other works like tiling, electrical, false ceiling is consider low. It is almost the price of contractor to contractor of different trade. Customer or home owner should never get such price usually. He just earn little bit for introducing other contractor to do your renovation.
The only thing is you need to pay extra care on the works. Because the profit margin is very thin. There is no room for this type of contractor (hungry for deal) to make mistake and to do extra services for you when you sign the contract. So just to be careful you does not end up mouth fighting if any modification is needed during your project.
Usually if i go direct to contractor, look for those with reasonable price/profit. So that the contractor give you good quality of works and more accommadating.
Hope this help.
thank you
1) Hacking works
2) Wet Works
3) Plumbing Works
4) Ceiling works
5) Other works
6) Carpentry Works
E.& O.E.
$ 42,763.00
$ 42,580.00
Note: Payment terms
10%-Upon Handover
Direct cost.
Total: $ 2,300.00
