Hi there , need advice from everyone.
Millions thanks .
My house is 4room resale , floor area is 950sf +- .
Got a quote from my friend contractor.
Is it the quote reasonable?
Millions thanks again .
Hacking
1 . Supply material and labour to hack floor and wall tiles for whole unit.
2 . Supply material and labour to hack sink support.
3 . Supply material and labour to remove kitchen cabinet and room wardrobe.
4 . Supply material and labour to hack wall for store room.
5 . Supply material and labour to hack door frame for store, 3 bedroom and toilets.
6 . Supply material and labour to hack kitchen entrance wall .
7 . Supply skip tank and remove rubbish.
8 . Supply material and labour to remove unwanted cornices.
Item 1 to 8 $3000 .
Wet works
1 . Supply material and labour to lay cement screeding and smooth cement plastering for living and 3  bedroom flooring $2000 .
2 . Supply material and labour to lay floor waterproofing for kitchen and 2 toilet $100 .
3 . Supply material and labour to make good damage cement wall ( hacking area) $200 .
4 . Supply material and labour to lay cement screeding with floor and wall tiles for kitchen and 2 toilet $5400 .
5 . Supply material and labour to construct base for washing machine and cabinet $250 .
6 . Supply material and labour to construct 3 room door frame $450 .
7 . Supply material and labour to replace new Dustbin $150 .
Plumbing works
1 . Supply material and labour to install s/steel piping ( hot and cold ) for kitchen and 2 toilet $1200 .
2 . Supply labour and tool to install 2 sitting bowl , 1 wall hung basin and 1 vanity basin $350 .
3 . Supply labour and tool to install 2 instant heater, 2 rain shower set and accessories for 2 toilet $200 .
Plastering/ painting
1 . Supply material and labour to plaster wall and ceiling for whole unit $2500 .
2 . Supply material and labour to paint wall and ceiling for whole unit with Nippon 5000 emousion paint $1000 .
Rewiring
1 . Single power point x 3 $150 .
2 . Double power point x 10 $550 .
3 . Data point x 2 $160 .
4 . Lighting point x 12 $360 .
5 . Heater point x 2 $180 .
6 . Fix light x 12 x $180 .
Vinyl flooring
1 . Supply material and labour to lay 5mm vinyl tiles with skirting for living hall, 3 bedroom and kitchen ( top up area ) $2800 .
Door
1 .  Supply material and labour to install Soild laminate door for 3 bedroom with lever lock set $750 .
2 . Supply material and labour to install fire rated Soild laminate door for main entrance with lever lockset $650 .
Carpentry works
1 . Supply material and labour to install 30’ top and bottom cabinet, pipe box up cabinet, build-in fridge cabinet , dish tray cabinet with glass door, internal with color pvc laminate, abs door trimming , soft closet and 1 roll drawer with laminate finishing $3300 .
2 . Supply material and labour to install 6’ sliding door wardrobe for 3 bedroom $4320 .
Quartz top
1 . Supply material and labour to install 10’ quartz table top for kitchen cabinet $850 .
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
