Paul Roger 0 Report post Posted April 30, 2020 Epic 5G Pro Vertical Rim Digital Lock (Rare!!!) In many cases, Korean rim digital lock is unable to install in most type of doors, therefore the vertical back body was introduced However, besides Gateman digital lock, EPIC is the second digital lock company that introduce vertical rim for Singapore HDB Door In most Singapore Condo, this is the only rim lock that is suitable, as the back body will not hinder by the pull handle if your back body of the digital lock is hinder or block by the pull handle, then you might face difficulty changing battery in the future My Digital Lock have listed out a series of door installation complete by EPIC 5G Pro Digital Lock onto most HDB Designer Fire Rated Door in Singapore Unique Feature (Vertical Back Body) Allows certain door to be able to install (Up to 90% Success Rate) 1. Door Pattern Stick out of the door (Don’t have to cut away the door pattern) 2. Pull Handle for condo is too close to the door (Suitable for most Condo in Singapore) 3. Door with glass at the center (The back unit will not be stick out) In some special case, you need the vertical rim lock to be install onto certain door If you find the EPIC vertical rim lock looks better than the horizontal one, purchase the pro version today Functions & Features 1. 100 Fingerprint 2. Up to 20 Cards 3. 1 Master Password 4. 1 User Password (One-time Password send remotely) 5. Bluetooth 6. WI-FI (Optional with $50 WIFI Bridge) 1+2 Years Warranty (3 Years Mobile App Support) First year would be full warranty, 2nd and third year for parts warranty subjected to $80 transportation However, our mobile application has a server themselves, therefore if you face any difficulty in the mobile app, our Korea partner will be able to assist you Unlike other smartphone digital lock. Our Digital Lock connects the Bluetooth through your mobile data 4G / 5G 1. Pull Handle That is Extremely close to the door frame For this type of cases, only our EPIC 5G Pro Vertical Rim Digital Lock is able to install onto it. As moving the pull handle away is almost impossible as certain condo disallow to do so 1.1 HDB Flat with Pull Handle Not only in condo, certain HDB owners would prefer to install the pull handle onto their new door as well Also, besides the pull handle case, EPIC 5G Pro vertical rim digital lock can be install onto normal HDB Door as well As the back body is suitable for any types of wooden door, for more information do visit our Facebook page weekly for the latest digital lock update 2. Don’t have to cut or chisel the HDB Door Pattern As you can see after installation, the HDB Door took no damage at all For customer do not wish to have major drilling or ugly chisel at the back of the HDB Door, you may consider this digital lock As this type of boxes HDB Fire Rated Main Door is commonly found under the resale flat With minimum drilling, which allows you to transfer away to your new house much more easier Call our sales hotline 90677990 or mobile showroom 98440884 to understand more 3. French Door / Aluminium Door with Glass at the center This type of door is commonly used in luxurious condo back door, landed, office or study room Many customers want to find a digital lock to install without seeing the back body of the digital lock sticking out of the glass which may look ugly Therefore, this digital lock will be the right one for you as shown in the photo Remember different types of door need to cater for different types of digital lock That is why My Digital Lock have spent many years to develop a full range of digital lock to install onto HDB and Condo door Review on EPIC 5G Pro Vertical Rim Digital Lock (Singapore) In My Digital Lock, the vertical rim lock has makes EPIC digital lock a more complete series Unlike many digital lock companies which only carry limited range of digital lock We have introduced new series of digital lock every 4 years with the latest smartphone features Now not only unlock using fingerprint, card or password, you can unlock using Bluetooth and WI-FI Hence this digital lock is getting more and more powerful at the price of $549 with 1+2 Years Warranty I would rate 7/10 for this digital lock Unlock EPIC 5G Digital Lock using Smartphone Most of the time, when you enter your home, all you need is to scan the fingerprint, card or key in pin number to unlock However, some of times, you will be away from home, therefore you can give access to the delivery man, house keeper, relative or guest By sending a guest key with time zone features, indicating the specific date and time After they unlock, you will receive a push message or notification The time attendance can be downloaded through desktop. Otherwise Unlock using WI-FI by adding $50 to Wi-Fi Bridge Note: The Wi-Fi Bridge depend on your Wi-Fi Strength and speed. If unable to connect relocate the Wi-Fi Bridge to other location and it should work 2 Yishun Industrial Street 1, #05-10, Singapore 768159 https://www.mydigitallock.com.sg/ Share this post Link to post Share on other sites
