d_kalos
Pls Help Review This Quotation. Thanks!
Hi Guys,
Please help to review this quotation for a 3-room condo.
The bulk of work is focus on the entrance to the house, living room and the 3 bedrooms.
Anything missing that I need to ask the contractor to add in or clarify with him. We are afraid of all the hidden charges that may surface during the renovation after we have signed the contract.
Thanks in advanced for all the help and advice given!
SCOPE OF WORKS
1 Kitchen
a) Hack and change carcass (cabinets above hood & sink)
and use existing aluminium door $ 1100.00
b) Spray kitchen door $ 130.00
c) (9’ x 2’) Wooden frame with laminated door for PUB meter $ 210.00
d) Movable L-steel bar Shelf (7’ x 80” x 20”) with 4 levels of plywood shelving $ 480.00
1a Kitchen Toilet
a) Hack and change from squatting to setting toilet bowl, tile and waterproofing to floor $ 1200.00
2 Entrance
a) Install entrance platform with concrete base and tile $ 1600.00
(under lay with chemical foam (2’ x 4’ x1”))
b) Entrance false ceiling above platform to screen $ 890.00
c) Bar counter above dry kitchen cabinet inclusive of light box
and at side wall and below table top (with similar solid surface tops #650) $ 2600.00
d) Partition screen in between dining and living consisting of 6 wooden strips
with laminate finish and integrated side table with storage underneath $ 950.00
3 Dining
a) Install glass feature wall with steel trimming $ 550.00
4 Living
a) False ceiling above living area $ 750.00
b) 6 panel glass feature wall with steel trimming $ 1480.00
c) Wall mounted TV console with laminate finish $ 650.00
5 Room 1
a) Construct top wall mounted cabinet and table top
with small concealed storage area beside window $ 1050.00
b) Construct seating surface above window parapet $ 350.00
c) Construct feature wall behind bed $ 480.00
d) To spray laminate cabinet (x 2 units) $ 1000.00
6 Room 2
a) Construct 100mm high platform with paint $ 1400.00
b) Construct extension to window parapet with sitting surface and storage $ 970.00
c) Construct 3 levels of open wall mounted cabinet $ 285.00
d) Construct feature wall $ 850.00
e) Construct false ceiling above platform area including 1-unit writing desk $ 900.00
7 Masterbed Room
a) Construct 100mm high platform $ 750.00
b) Construct window sitting area with retractable table surface $ 495.00
c) Construct false ceiling $ 600.00
d) Construct feature wall for wall mounted TV $ 520.00
e) Construct dressing table $ 350.00
f) Construct cushion wall panels $ 500.00
g) Hack off partition wall (8’ x 62”) $ 320.00
8 Additional
a) Spray paint 5-units door and door frame $ 950.00
b) Wooden carcass shelving along passage-way $ 210.00
c) Painting to whole house (ICI Paint) $ 1300.00
d) Louvre-door shoe cabinet (2’ x 6’ x 18”) with lock $ 490.00
Total Cost = $26,360
Edited by d_kalos
