Aircon Quotes (From Aron)
Hi, I would like to enquire on the prices for the following:
-starmex sys 4 (9btu x3) + 22btu
-16mm drainage piping
-22G copper piping
-1/2 inch insulation
I have PMed to you.
Thank you,
Aron (aronputt@gmail.com)
  • Replies 2.1k
  • Views 658k
  • I was told my a saleman selling aircon that the default grey insulation is good enuff if your aircon trunking is expose as most of the HDB are. And not hidden as those in the condominium. Armaflex ar
  • ok, there are retailers who try to cut corners to save $$. eg. they offer you system 3 at (est) $3.4k, generally the air-con mfgr specs will specify wat type of material to use, eg. for insulation, pi
  • i got a quote from gain city. Mitsubishi invertor, compressor is 30k btu, then 3X 9k units for 3 rooms, and a 22k unit for the living area. Cost is $3.4k. is it cheap? TO be honest, im a noob when it
Hi Aron,
Pls quote latest inverter system 3 series for Daikin & Mitsubishi.
It is to install in 2 roooms + living room.
Thanks.
I have just PMed to you.
Thank you,
Hi Aron,
Can I get quote for Inverter System 2 & 1 window casement unit (Daikin, Mitsubishi, Fujitsu) 12k + 9K and 9k.
Thanks.
Edited by ardi
Hi Aron,
Can quote me system 4 (9btu x 4) for the below brands?
York
Panasonic
Mitsubishi starmax
Mitsubishi Heavy industrial
I need dismantle and disposal of old unit.
Mitsubishi starmax
what is the different btw these 2 model?
looking for 1 to replace my old aircon too
Hi Aron,
Thanks.
Thank you,
Hi Aron,
York
Panasonic
Mitsubishi starmax
Thank you,
Mitsubishi starmax
Thank you,
Hi aron. i am looking for to replace my old single Sanyo . Currently looking at Mitsubishi single and i also need to replace my socket into waterproof or maybe shift it to indoor. kindly advise
Thank you,
Hi Aron,
Kindly forward me the best quote (all in-installation, delivery, stainless steel brackets and such) and model number of the following 3 brands:
-Panasonic
-Toshiba
-Mitsubishi
All only need to be single split and the lowest BTU.
Thank you so much :)
Regards
Simple13
Hi Aron, would like to ask for quotes on Mitsubishi and Panasonic Inverter System 4 for new 4 room bto flat.
For your prompt reply
Thank you
Hi Aron,
I intend to put up 3 in 1 for 3 rooms, and 2 in 1 for Living room and study room, Mitshubishi inverter system, can you quote me?
regards,
dixon
Hi Aron,
-Panasonic
-Toshiba
-Mitsubishi
Regards
Simple13
Thank you,
Thank you
Thank you,
