shibumi
How Many Kinds Of "2-Way" Switch Implementation Are There?
Hi fellows. May I know how many kinds of 2-way switch implementation are there? It seems like there is a kind of 2-way switching that does not require the (light) switch itself to be a "2-way" while there is another kind that requires the physical switch to be 2-way. My own impression is that 2-way switches simply means the same single appliance, e.g. one lamp, to be able to be powered on/off from 2 physical switches. What's the other kind?
The other kind is an electronic switch. Suppose you have 2 lights; it toggles between off, one light on and both lights on.
It is not actually a 2 way switch, though it can act like one.
More common is 1 or multiple lights controlled by 2 or more physical switches.
You are better off with the physical type; i.e. two physical 2 way switches. You can have 3 or more if you want. Very reliable.
There are two different ways of wiring physical 2 way switches but the net effect is the same.
Two way switches are such a convenience especially if you don't have to get out of bed and fumble in the dark to on/off the room or toilet light.
