simplesweet
5 Rooms Hdb Flat Renovation Quotation
Hi All, just got a quoptation from a contractor, appreciate if you can help to see if it's reasonable? Thanks!!!
1. Supply labor & tiles to lay 641sqft homogenous tiles for 3 bedrooms,
Passageway, suggestion study, Living & Dining (Not more than $3.20 tiles)
641sqft x $8.00 per sqft $5128.00
2. Supply labor & tiles to run 260ft homogenous tiles skirting 3 bedrooms,
Passageway, suggestion study, Living & Dining 260ft x $6.00 per ft $1560.00
3. Supply haulage, clear debris, cement, sand, W1 and delivery of material $850.00
4. Supply labor to construct kitchen base, washing machine base $450.00
5. Supply labor to construct L-box @ Living area 48.5ft x $13/- per ft $630.50
6. Supply labor to construct false ceiling @ Dining area & suggestion study
214sqft x $4/- per sqft $856.00
7. Supply labor to install 2 units of instant water heater @ 2 toilets
$60/- per unit x 2 unit $120.00
8. Supply labor to install 2 sets spray gun @ 2 toilets $50/- per set x 2 sets $100.00
9. Supply labor to connect kitchen sink tap $90.00
10. Supply labor to dismantle the existing sink & connect install sink & tap @ common toilet $120.00
11. Supply & install 10mm thick clear glass temper glass divider @ Master toilet $250.00
12. Supply & install L-shape power coated aluminum Acrylic sliding door @ common toilet $580.00
13. Supply & install L6ft x 8ft clear mirror @ Dining area wall (with false ceiling) $960.00
48sqft x $20/- per sqft = $960.00 (option 1)
14. Supply & install L6ft x 8.5ft clear mirror @ Dining area wall (w/o false ceiling)
51sqft x $20/- per sqft = $1020.00 (option 2) $1020.00
15. Supply & install L6ft x 8ft grey mirror @ Dining area wall (with false ceiling)
48sqft x $28/- per sqft = $1344.00 (option 1) $1344.00
16. Supply & install L6ft x 8.5ft grey mirror @ Dining area wall (w/o false ceiling)
51sqft x $28/- per sqft = $1428.00 (option 2) $1428.00
17. Supply & install L4ft suspended carpentry vanity cabinet @ Master toilet
Using plywood, internal with white pvc, external with laminate finish
Swing door with soft close hinges & ABS edging $120/- per ft x 4ft $480.00
18. Supply & install 5mm L4ft x H5ft clear mirror sitting on top the solid table @ Master toilet
$20/- per sqft x 20sqft $400.00
19. Supply & install L3ft suspended carpentry vanity cabinet @ common toilet
Swing door with soft close hinges & ABS edging $120/- per ft x 3ft $360.00
20. Supply & install L3ft solid surface top for vanity @ common toilet
$75/- per ft x 3ft $225.00
21. Supply & install L3ft x H5ft 5mm clear mirror @ common toilet
15sqft x $20/- per sqft $300.00
22. Supply & install L6.5ft x L6ft L-shape modular system closet @ Master room
C/w partition frame, internal using melamine board with free configuration,
Aluminum glass sliding door 1st 5ft - $1500/- Additional ft - $250/-
12.5ft – 1ft @ corner = 11.5ft – 5ft = 6.5ft x $250/- per ft = $1625/-
$1500/- + $1625/- = $3125/- $3125.00
23. Supply & install L6ft modular system closet @ Bedroom 2
6ft – 5ft = 1ft x $250/- = $250/- + $1500/- = $1750/- $1750.00
24. Supply & install L6ft modular system closet @ Bedroom 3
25. Supply & install L6.5ft modular system closet @ Suggestion Study
Aluminum glass biford door 1st 5ft - $1500/- Additional ft - $250/-
6.5ft – 5ft = 1.5ft x $250/- = $375/- + $1500/- = $1875/- $1875.00
26. Supply & install L6ft x H6ft (36sqft) feature wall for TV console @ Living
Using plywood, laminate finish $22/- per sqft x 36sqft = $792/-
Supply & install L8ft suspended carpentry TV console @ Living
Using plywood, internal pvc white, external laminate finish
$120/- per ft x 8ft = $960/- $1752.00
27. Supply & install L7ft wooden plank @ Bedroom 2 & 3
Using plywood, laminate finish 7ft x $35/- per ft x 2 bedrooms $490.00
28. Supply & install 10mm thick frosted swing door temper glass @ kitchen entrance $580.00
29. Supply & install L22ft Top & bottom kitchen cabinet, using plywood, internal pvc white,
External laminate finish. C/w 1 cutlrey tray, 1 s/steel dish rack, all swing doors with soft
Close hinges & ABS edging
Top Cabinet - $120/- per ft x 7.5ft = $900/-
Bottom cabinet - $120/- per ft x 14.5ft = $1740/-
Supply & install 14.5ft Quatz table top - $120/- per ft x 14.5ft = $1740/-
Supply & install 2 sets of BLUM drawer track runner 30kg - $60/- per set x 2 sets = $120/- $4500.00
30. Supply & install L3.5ft x H8ft Full height carpentry shoe cabinet @ infront of foyer
Using plywood, internal pvc white, external laminate finish.
$280/- per ft x 3.5ft $980.00
31. Supply labor to acid wash floor after renovation $300.00
Optional Items
• The bath room accessories installation per items - $8.00
u got ur quote from contractor or ID company?
if it from contractor this quote consider expensive, only the carpentry work still reasonable.
In term of overall quote i believe u can get cheaper then this if u r looking for contractor to do the job.
If u interested i can give u my contractor contact for u to compare price. :)
No harm getting a few more quote.
Cheers!!
Optional Items
