Are local wallpaper installers worth it compared to big renovation companies?
I’m weighing two options for an upcoming wallpaper project and wanted to hear some real opinions. On one hand, big renovation companies offer everything under one roof. On the other, local specialists seem more focused on one craft. The job includes a few bedrooms and a hallway with detailed patterns, so clean seams and alignment matter more to me than speed. I’m curious whether larger companies actually deliver the same level of precision for wallpaper, or if it ends up being treated as a minor add-on service. Did local installers feel more invested in the final result, or did the scale of a bigger company make things smoother?
I’ve gone both routes, and honestly, there’s a noticeable difference. Big renovation companies are great if you’re doing a full remodel and wallpaper is just a small add-on. But in most cases, wallpaper isn’t their main skill—it’s just another box they check. That’s where things tend to go wrong: rushed installs, misaligned patterns, and seams you can’t unsee once the room is finished.
With local wallpaper installers https://bestwallpaperinstaller.com/, the experience felt completely different. They actually talked through the wall conditions, the pattern repeat, and where seams would land before starting. That alone saved a lot of frustration. The installer clearly knew how unforgiving wallpaper can be and treated it like a finish, not a shortcut.
Another big plus was communication. It was easy to ask questions, make small adjustments, and get honest answers instead of vague “we’ll make it work” responses. The final result held up over time too—no lifting edges or bubbling weeks later. If wallpaper is a major visual element in your space, I’d personally choose a specialist every time. Big companies are convenient, but for wallpaper specifically, focused expertise usually wins.
