Brandcalfe 4 Report post Posted September 27 I’m interested in hearing from people who have actually tested Aviator predictor apps for a reasonable amount of time rather than just trying them for a few rounds. If someone has used one regularly, how did you determine whether it was useful? Did you record every prediction before seeing the actual result and then compare the two, or did you mostly follow the signals as they appeared? I think the testing method makes a big difference here. Share this post Link to post Share on other sites
JustinDavidson 10 Report post Posted September 27 I agree that recording the predictions beforehand would probably be the fairest way to test something like this. Otherwise it’s incredibly easy to remember the predictions that happened to be correct and forget all the ones that missed. I found aviatorpredictor.in while researching different predictor apps, and if I were testing it, I’d keep a simple record of every prediction and actual outcome over a large sample. That would give you a much better idea of how consistent the tool really is than a handful of screenshots showing successful calls. Share this post Link to post Share on other sites
