Guest kennygoh
Small Reno Work Needs Help On Budgeting
Guest kennygoh
Hi any idea how much i need to prepare for the following work? Any contractor willing to take on this work which you all can recommend? Any obvious work I have MISSED OUT in the list?
Really appreciate any input. Thanks in advance!
We plan to use IKEA kitchen cabinets, can slowly buy bit by bit over a period of time.
Attached is a copy of my floor plan.
This is a 6 years old resale flat in Anchorvale Road.
We intend to renovate MAINLY the kitchen & 2 toilets in early Dec 2007 and finish in mid Jan 2008.
Due to budget constraint :( we ONLY can do the following work
Kitchen
Remove & dispose existing built-in kitchen cabinets
Labor to hack existing HDB floor
Labor & materials to waterproof floor
Labor & materials (excluding floor tiles) to lay floor tiles
Cost of floor tiles (psf and total)
Please list any other work and cost needed to complete the above
Toilet (Common)
Labor to remove & install toilet bowl
Labor to remove vanity top with basin & install basin
Install a storage water tank for use in both toilets
Labor to install shower point
Change piping for both basin & shower point
Toilet (Master bedroom)
Change piping for basin & shower point
Living Room
Remove a praying altar built-in cabinet
Patch the affected cornice
Others
Chemical washing
If we can find more $$$ than MIGHT BE doing the following work too :(
Optional - Toilet (Common)
Labor & materials (excluding floor titles) to overlay on existing HDB floor
Optional - Toilet (MasterBedroom)
Labor to hack existing HDB wall
Labor & materials (excluding wall titles) to lay wall tiles to ceiling
Cost of wall tiles (psf and total)
Labor & materials to built shower curb
Labor & materials to install a 10mm tempered clear glass shower door (1 x fixed & 1 x door)
Labor & materials to remove existing door & install a 10mm tempered clear glass swing door w design
Optional – Master bedrooms
Remove & dispose a 4 door built-in cabinet
Remove & dispose a 3 door built-in cabinet below window area
Optional – common bedroom-1
Remove & dispose a built-in study desk
Optional – common bedroom-2
Remove & dispose a 2 door built-in cabinet
Optional - Others
Patch holes & Painting whole house wall & ceiling with supreme paint, number of color selection
Painting main door, main gate, 3 x bedroom doors, kitchen bi-fold door, all door frames, all piping
Edited by kennygoh
guess your works are mainly removal + hackntile kitchen + repainting(cos patching cornice)
hacktile kitchen minimum - $3-4k liao.
repainting you need to get a contractor liao - cos you mentioned too many holes + patching
get the same contractor to do the removal+patching+repainting.
nipponpaint - they dont patch hor, unless a few very tiny holes.
Kitchen
Remove & dispose existing built-in kitchen cabinets(shoud be free)
Cost of floor tiles (psf and total) - around $3
Toilet (Common)
Labor to remove & install toilet bowl - removal is free, they usually charge installation only.
they will charge you ;
1) piping
2) install storage heater + heater wiring
3) shower point included in piping.
Guest kennygoh
Hi MaCe,
Thanks for your response.
I have email my request to 2 contacts received in RENOTalk (Henry@impress21design & Mr.Ooi@Joo Hua Furniture) few days ago. But both haven't response yet.
Hope to firm a contractor very soon.
Cheers,
Kenny
Hi MaCe,
Cheers,
Kenny
any contractor who can reply you immediately i guess you better leave them out - now market boom time everyone is busy hehe.
Guest kennygoh
below is a quotation given to me by INNER VIEW - IMM ID. looks ok or not?
any comment for this ID? good or not huh?
thanks in advance for any responses.
DESIGN SERVICES.
Interior Design Consultation. Complementary
Space Planning. Complementary
Perspective Drawing. Complementary
Soft Furnishing Consultation. Complementary
Site Co-Ordination and Supervision. Complementary
1 LIVING / DINNING HALL.
a Dismantle existing Altar Cabinet **** Hall. $40.00
b Additional & Alteration of existing Simple decorative Cornices at Altar Ceiling area. $150.00
2 BEDROOM 3.
a Dismantle existing Build In Wardrobe & Storage Cabinet below Window area. $60.00
3 BEDROOM 2.
a Dismantle existing Build In Wardrobe, Storage Cabinet below Window area & $100.00
Study Table cum Shelves.
b Additional & Alteration of existing Simple Decorative Cornices at existing $150.00
Wardrobe area.
4 MAIN BEDROOM.
a Dismantle existing Build In Wardrobe. $50.00
Wardrobe area.
c Replace 3 Panels existing Storage Cabinet's Doors to selected High Pressure $285.00
Laminate Finishing below Window area.
5 BATH / W.C 2 ; COMMON TOILET.
a Hack Off existing Wall Mount Vanity Top includes Replace Damaged Wall Tiles. $100.00
* Selected Wall Tiles Only Close Color to existing Wall Tiles.
b Material Cost for selected Heavy Duty Designer Homogeneous Floor Tiles. $160.00
* Size of Designer Homogeneous Floor Tiles : 300mm by 300mm.
* Designer Homogeneous Floor Tiles Per Square Feet : S$ 3.00.
c Labor Charge ( Workmanship ) to Over Lay existing Flooring with selected Heavy $280.00
Duty Designer Homogeneous Floor Tiles includes Chemical Adhesive Cement,
Chemical Strengthener Bonding Membrane ( W.1 ), Grouting ( Color Cement ) for
Tiles Gaps.
6 BATH / W.C 1 ; MASTER TOILET.
a Hack off existing PVC Door & Frame includes Touch Up smooth with Chemical Easi- $80.00
Plaster Cement.
b Supply and install One Panel custom Cut Frameless Clear / Sandblast Tempered $440.00
Glass ( 10mm Thick ) Swing Door includes One Set Stainless Steel ' H ' Design
Handle, Heavy Duty Wall Mount Hinges.
* Size : ( L ) 850mm by ( H ) 2050mm by ( T ) 10mm.
c Hack Off existing Wall Mount Vanity Top includes Cabinet below. $50.00
d Material Cost for selected Heavy Duty Designer Homogeneous Floor Tiles. $160.00
e Labor Charge ( Workmanship ) to Over Lay existing Flooring with selected Heavy $280.00
Tiles Gaps.
f Construct One Length 50mm Height Concrete Shower Kerb with selected Designer $60.00
* Size : ( L ) 1500mm by ( W ) 50mm by ( H ) 50mm.
g Supply and Install One Panel Fix by One Panel Swing Door custom Cut Frameless $580.00
Clear Tempered Glass ( 10 mm Thick ) Shower Screen includes One Set Stainless
Steel Towel Handle & Heavy Duty Wall Mount Hinges.
* Size of Fix Panel : ( L ) 700mm by ( H ) 1750mm by ( T ) 10mm.
* Size of Swing Door : ( L ) 800mm by ( H ) 1750mm by ( T ) 10mm.
h Hack off existing Ceramic Wall Tiles Up to Ceiling Height All round. $250.00
i Material Cost for selected Designer Ceramic Wall Tiles. $625.00
* Size of Designer Ceramic Wall Tiles : 300mm by 450mm.
* Designer Ceramic Wall Tiles Per Square Feet : S$ 2.50.
j Labor Charge ( Workmanship ) to Lay selected Designer Ceramic Wall Tiles Up to $850.00
Ceiling Height All round includes Plaster Sand & Cement, Chemical Strengthener
Bonding Membrane ( W.1 ), Grouting ( Color Cement ) for Tiles Gaps.
7 KITCHEN.
a Dismantle All existing Top & Bottom Kitchen Cabinet. $150.00
b Hack off existing Floor Tiles cum Sand & Cement Screeding includes Concrete $150.00
Raise Bases.
c Supply and Lay Chemical Waterproofing Solution at existing Floor area. $100.00
* Anti-Leakage ; Warranty Period : 24 Months.
d Material Costs for selected Heavy Duty Designer Homogeneous Floor Tiles. $400.00
* Country of Homogeneous Tiles : China : Size : 300mm by 300mm.
* Homogeneous Floor Tiles Per Square Feet : S$ 3.00.
e Labor Charge ( Workmanship ) to Lay selected Heavy Duty Designer Homogeneous $550.00
Floor Tiles includes Sand & Cement Screeding, Chemical Strengthener Bonding
Membrane ( W.1 ), Grouting for Tiles Gaps.
f Fabricate and install custom made Wall Mount Top Portion Cabinet with Solid Ply- $1,050.00
Wood c/w selected High Pressure Laminate cum ABS Trimming Finishing includes
Compartment, One Unit Colored Glass Design Flip-Up Door c/w Hydraulic Air-
Spring, Internal White Carcass Shelving, Heavy Duty Hinges, Recess-In Designer
Handles.
* One Set Double Tier Stainless Steel Dish Tray. $125.00
* Perspective Detail Drawing Provided
* Size : ( L ) 3200mm by ( D ) 300mm by ( H ) 950mm.
g Fabricate and install custom made Suspended ' L ' Shape Design Bottom Portion $1,350.00
Cabinet with Solid Ply-Wood c/w selected High Pressure Laminate cum ABS
Trimming Finishing includes Compartment, One Chest of Drawers, Internal White
Carcass Shelving, Heavy Duty Hinges, Recess-In Designer Handles.
* Size : ( L ) 4100mm by ( D ) 600mm by ( H ) 650mm.
h Supply and install custom made ' L ' Shape Design Kitchen Cabinet Work Top with $1,012.50
selected Solid Surface Materials includes Original Backflush / Skirting, selected
Front Edge Profiles cum Opening for Sink & Cooker.
* Size : ( L ) 3000mm by ( D ) 600mm by ( T ) 12mm.
* Size : ( L ) 4100mm by ( D ) 600mm by ( T ) 12mm.
i Fabricate and install custom made Ceiling Height Box-up existing Sewerage Pipes $330.00
Trimming Finishing includes Heavy Duty Hinges, Recess-In Designer Handles.
* Size : ( L ) 300mm by ( H ) 2550mm by ( W ) 450mm.
8 PLUMBING & SANITARY WORKS.
a Dismantle existing Water Inlet & Drainage Outlet Pipes, Toilet Bowl / Cistern Tank, Complementary
Wash Basin / Tap, Heater, Mirror Accessories at Both Bath / W.C & Kitchen.
b Supply and install Stainless Steel Water Inlet Piping ( Cold Water Only ) at Both $550.00
Bath / WC & Kitchen. * Expose Piping *
c Supply and install Stainless Steel Water Inlet Piping ( Hot Water Only ) Direct from $180.00
Gallant Storage Heater at Bath / W.C 2 . * Expose Piping *
d Supply and install New UPVC Drainage Outlet Pipes for Kitchen Sink, Wash Basins, $80.00
Washing Machine.
e Labor Charge to install : ----------------
2 Sets -- Toilet Bowl cum Cistern Tank. $150.00
2 Sets -- Wash Basin cum Tap. $90.00
2 Sets -- Mirror Accessories includes Toilet Paper Holder, Towel Rails, Etc… $150.00
2 Sets -- Floor Spray cum Holder. Complementary
1 Set -- Gallant Storage Heater cum Bracket. $80.00
1 Set -- Kitchen Sink cum Tap. $65.00
1 Set -- Cooker cum Hood. $80.00
* All The Above Mentioned Accessories Supplied by Owner.
9 PAINTING WORKS.
a Supply and Paint Whole Unit Wall cum Ceiling areas with selected Colors. $950.00
* ( Maximum 08 Colors )
* Wall Areas : ICI ; Emulsion Paint : Dulux Supreme 3 IN 1 or Wash & Wear.
* Ceiling Areas : ICI ; Emulsion Paint White.
b Supply and Paint existing Wooden Main Door & Frame, Metal Main Gate & Frame, $250.00
Bedrooms Doors & Frames, UPVC Waste / Sewerage Pipes with selected Colors.
* ICI ; Enamel Paint : Dulux Glossy Finishing.
10 OTHERS.
a Labor Charge for Haulage Services & Hoisting of Materials to Work site. $150.00
b Labor Charge for Clearing Debris Out of Work Site include Transportation to MOE $350.00
for Disposal.
c Chemical Washing for Whole Unit Flooring includes General Cleaning of All Complementary
Windows & Grilles.
d Submission to HDB for Renovation Approval includes Permit Fees. Complementary
e Supply and Lay Protective Corrugated Paper Over Newly Laid Homogeneous Tiles. Complementary
TOTAL AMOUNT FOR ITEMS 01 TO 10. $13,242.50
DISCOUNT GIVEN. $442.50
GRAND TOTAL AFTER DISCOUNT. $12,800.00
Terms And Conditions
1 Changes made during construction would be acted only written order and the work will be invoiced
accordingly on labor and material incurred.
2 All additional work will be invoiced accordingly.
3 Cancellation of confirm order , deposit will be forfeited.
4 All payment must be payable to Inner View Design & Contracts Pte Ltd
5 All goods on site remain as property of Inner View Design & Contracts Pte Ltd until full payment of the
agreed contract is made.
6 Mode of payment : 10% upon confirmation
40% upon delivery of material to site
20% upon confirmation of carpentry work design to construct
20% upon construction of carpentry work on site
10% upon completion exclude items ( Additional & Alteration Works )
Hi MACE
hahahaha good advice!!
Anyway, at least reply back and inform will quote you in a few days time, rather than no news at all.
