Recommendation Needed For Parquet Floor Repair
There is a crack on my room's parquet floor near the toilet and water is seeping in.
Does anyone has any recommendation for parquet floor repair with good workmanship? It would be good if anyone can share the cost for such repairs cos I'm on tight budget :P
Does anyone has any recommendation for parquet floor repair with good workmanship? It would be good if anyone can share the cost for such repairs cos I'm on tight budget :dancingqueen:
Since you are on budget , maybe you can try to DIY, using wood patty? you can find them in Home fix. jus fill up the crack and varnish a little will do.
But if you looking for a perfect repair, likely a professional has to come in to remove the cracked pc and select to the most matching color of your mature wood. That will cost you around $80 per pc not including transport and labour.
Having said that, it not advisable to remove any pc of parquet cos they are joint by tongue & groove , so you have to ensure proper maintenance over the area repaired. If not over time tat pc will come loose too.
  • 2 months later...
wow parquet is pretty expensive by itself, yea and i second quessisabel's reply. if you're on tight budget, diy is the way
there is co specialised in parquet - always advertise in ST classified ads.
forgot the number - only remember it ends with 1101 or 1011...
DIY
1) hairdryer
2) wood putty
3) sandpaper
4) silcion
5) shellac
Hi ,
May i know if you have used their services before and how much did you pay them.
DIY
1) hairdryer
2) wood putty
3) sandpaper
4) silcion
5) shellac
Hi ,
end up my contractor got them(sub con) instead. good job.
  • 1 year later...
Thanks to Mr Wood Varnish. PRO and clean job DUST FREE. Never thot it will be true DUST FREE coz previously i had very bad experience with my Ex-contractor. if you wish check website n there's Toll Free no. 1800-VARNISH
  • 8 months later...
Does anyone has any recommendation for parquet floor repair with good workmanship? It would be good if anyone can share the cost for such repairs cos I'm on tight budget :(
we surf renotalk, google, ...mr Wood Varnish came up very professional & specialise in parquet floor restoration. They are knowledgeable and explained in details every steps n i learnt alot about parquet maintenance too. Never expect our parquet floors cracks/ gaps n damaged pcs can be restored as NEW after job done by them. Highly recommended :D
hey thanks Soconfused. It's ur comments tt we decided to go for Mr Wood Varnish. This guys exactly what we need for parquet floor polishing job. alot cheaper compared to my ID who quoted me. Their equipment with vacuum alike bags truly amazing n effective.
  • 1 year later...
Having read the generally positive reviews about Mr Wood Varnish on this thread, I decided to get them to sand and revarnish my wooden floor. Bad choice ! Not only did they do a poor job (used the wrong type of varnish) but also dragged the job on for weeks eventhough they told me a few days to complete the job (presumably becoz they had other more important work to do). I would not recommend them ever again ! Maybe my bad luck in getting a lousy staff appointed to handle my case I dunno but I think it their attitude reflects poor management.
  • 6 months later...
recently i engaged mrwoodvarnish before seen this forum.
last week used them to do up 3bdrm $600 @ livia condo completed in one day- fantastic job! ( Contary to Fourroom comment )
dust free sanding using impressive machine- of course dun expect absolutely zero lor.
To me, they are good. puncture, no delaying, honest & reliable. the flooring so nice after done - thumbs up!
