cwongst
Roller Blind
Installed roller blinds in the rooms but when the wind comes.. Oh gosh! The blind will knock against the wall.. so noisy.. Is there any solution to reduce the noise??
I rem reading this thread somemore in this forum but I can't seem to be able to find it.
i m installing blinds soon , this solution was propose to me when i highlighted this issue to them. the noise come abt due to the ending drop pole hitting the contact point, so at these contact point , they stick thoise 3 m tapes which is thick enuf to act a cushion
hope it helps
hope it helps
I use the 3M Bumpons. Pretty good and hardly visible.
can advise how much did your spent on doing the roller blinds? i was charged $150 per panel(equivalent to 2 window doors)....
Thanks in advance!
