October 26, 200818 yr Is this consider Storage Heater or Instant Heater? As it seems to be have both their features??
October 26, 200818 yr only instant gas heaters are approved for HDB use so if this is the hdb version, then it's instant
October 27, 200818 yr Author Really? But you see the specs as below...don't seems like a Instant Heater leh. REU-8 CG Gas Water Heater Do you often have to waiting for some time to get warm water for showering or to fill up the bath tub for a good stress-out soak? Well, with gas water heater, you will be able to enjoy instantaneous hot water anytime you need! FEATURES - No storage tank required - Water is only heated on demand, no storage tank is required to heat and store the water. - Instantaneous and continuous flow of hot water - Just set the heater at your desired temperature. All you need is to turn on the tap and unlimited supply of hot water is available for your usage. - Availability of hot water at multiple point - Able to supply hot water to 2 shower points in 2 separate bathrooms concurrently. - Ease of operation - User-friendly in design and usage. - Batteries operated, no electricity required - Do not require any electric supply thus no wiring required. - Built-in safety features - Giving peace of mind to users with built in overheating protection, flame failure and incomplete combustion devices. - Low running cost - Gas tariff is typically lower than Electricity tariff by about 20%*, thus you save more using Gas. - Compact in size - Slim and compact design that fits well in the kitchen or yard space with no exhaust flue required SPECIFICATIONS Model: City Gas – Rinnai REU-8 CG Colour: Metallic Silver Dimensions: H 372 mm x W 290 mm x D 136 mm Hot Water Capacity: (Raised 25 degree celsius) Max. Hot Water Volume: 8.0 L/min (water pressure 50 kPa) Min. Hot Water Volume: 3.0 L/min (water pressure 50 kPa) Min. Operating Water Pressure: 0.20 Kgf/cm2 Automative Spark Ignition: Yes Gas Consumption: 37.7 MJ/h Weight: 5.7 (31) Kg(lb)
October 27, 200818 yr Really? But you see the specs as below...don't seems like a Instant Heater leh. REU-8 CG Gas Water Heater Do you often have to waiting for some time to get warm water for showering or to fill up the bath tub for a good stress-out soak? Well, with gas water heater, you will be able to enjoy instantaneous hot water anytime you need! FEATURES - No storage tank required - Water is only heated on demand, no storage tank is required to heat and store the water. - Instantaneous and continuous flow of hot water - Just set the heater at your desired temperature. All you need is to turn on the tap and unlimited supply of hot water is available for your usage. - Availability of hot water at multiple point - Able to supply hot water to 2 shower points in 2 separate bathrooms concurrently. - Ease of operation - User-friendly in design and usage. - Batteries operated, no electricity required - Do not require any electric supply thus no wiring required. - Built-in safety features - Giving peace of mind to users with built in overheating protection, flame failure and incomplete combustion devices. - Low running cost - Gas tariff is typically lower than Electricity tariff by about 20%*, thus you save more using Gas. - Compact in size - Slim and compact design that fits well in the kitchen or yard space with no exhaust flue required SPECIFICATIONS Model: City Gas – Rinnai REU-8 CG Colour: Metallic Silver Dimensions: H 372 mm x W 290 mm x D 136 mm Hot Water Capacity: (Raised 25 degree celsius) Max. Hot Water Volume: 8.0 L/min (water pressure 50 kPa) Min. Hot Water Volume: 3.0 L/min (water pressure 50 kPa) Min. Operating Water Pressure: 0.20 Kgf/cm2 Automative Spark Ignition: Yes Gas Consumption: 37.7 MJ/h Weight: 5.7 (31) Kg(lb) Yo Bro, It is a instant heater.. see abv in blue and bold.. You only get hot water from storage heater in approx 15 mins because it needs to heat up the water stored in it..
October 27, 200818 yr yah loh, those in blue and bold points to a instant heater mah all cannot be done by storage heater
December 3, 200817 yr i know this question was asked before but seem like those are a different model compare to the one posted on citygas website. Anyone use the latest model? Any complain?
December 10, 200817 yr Anyone use this REU-8 CG GAS WATER HEATER Any feedback, is it good? I mean by the waiting time? Is it better than storage heater? For this, do we have to lay cold and hot pipe for this?
December 19, 200817 yr Just to ask again.. this one really have to wait for 15 minutes for the water to heat up is it?
December 23, 200817 yr hi, i also thot of installing this as its on promo nw, ending 31.12.08. but my reno wil only begin in mid-jan. its wifin our budget, considering its $168 incl of installation. quite cheap rite??
December 23, 200817 yr Just to ask again.. this one really have to wait for 15 minutes for the water to heat up is it? if you are staying in a hdb flat then the answer is no only the instant model is allowed for use in hdb flats however, if you are staying in a private property AND taking the storage tank models then you got to wait for the water to heat up why it takes a while to get hot water from your tap is because the cold water already in the pipe needs to be pushed out so if the tap is right next to the heater, it'll take something like 3 sec to feel the water heating up :notti:
December 24, 200817 yr I am staying HDB, citygas technical came to my house say I am able to install. I am just trying to find out, will I have to wait long for the hot water while having my shower. If the pipe is 7.7m away from the gas heater point, how long will it take?
December 24, 200817 yr i'd give about 30 sec :dunno: currently will fill a big red pail of water before it's steaming hot using the water to wash my wc so no wastage there
