Cost Of Changing From Squatting To Sitting Toilet Bowl
We have called a few places about changing the squatting toilet bowl in our 3-rm flat to a sitting one. Two quotes are about $1k, and the 3rd one from a company called "A-class services" (http://sg.88db.com/sg/Services/Post_Detail.page/home_services/painting_renovation/?PostID=415756) is $650 if they only re-tile the step up but not the rest of the bathroom floor. $800 includes tiling the rest of the bathroom floor, and both prices include the cost of the toilet bowl.
Has anyone here used their services before? Are they reliable? Is the $1k quote more usual for this kind of work?
Any advice greatly appreciated.
  • 2 months later...
Hi I am looking to convert by toilet in the kitchen from a squat to a sitting one. Is the relevant party to contact called a plumber or contractor. Anyone can kindly help recommend a company that does such job? Thanks.
U nid a contractor to do the job... Permit application needed...
Call your Town Council for recommended contractors. they have a list of recommended ones. The prices are not cut throat type, coz they are monitored by Town councils.
  • 1 year later...
Converting Squatting Toilet Into Sitting Toilets anyone know the price? thank you
Please help to recomend a qualified contractor who can change toilet bowl from squatting-type to sitting-type!
What're activities should be done? any reference quotations?
Thanks a lot!
any HDB licence contractor can do it.
U can found 1 whole long list @ HDB web.
I change my toilet bowl from squatting-type to sitting-type.
Things done
hack away the floor
do the waterproof
change the toilet bowl.
My contractor charge me
1. hack common toilet squatting bowl and install PVC pipe - $250
2. hack common toilet floor tiles and supply install and relay new floor tiles (include water proof) $680
3. supply and install toilet bowl $280
Total $1210 for 1 toilet.
Plumbing Work
Convert squatting to sitting (hack/dismantle existing squatting pan and install with new pedestal bowl) - $250
Wet Work
Tiler to lay new tiles to affected or (entire toilet flooring) area after hacking - depending on the condition and size of the area
Note: waterproofing is a must
Hope it will help you
Regards
Things done
hack away the floor
do the waterproof
Thanks, Therat!
Can we skip the 2nd step - 'hack common toilet floor tiles and supply install and relay new floor tiles (include water proof)'?
The toilet was upgraded around 3 years ago, floor tiles & waterproof is still in good condition.
By the way, could you send me your contractor's phone num?
Cheers,
Michele
Thanks, Therat!
Cheers,
Michele
The squatting and sitting type. The hole distance is different.
I prefer to do the the floor.
Don't want .. done liao.
downstair neigbour complain leaking.. then I had to re-do the toilet again.
I will PM you later regarding his contact.
Things done
hack away the floor
do the waterproof
can i have the contact too, thank you
Things done
hack away the floor
do the waterproof
Can PM me the contractor contact? Thanks.
Plumbing Work
Wet Work
Regards
I am also looking for someone to Convert squatting to sitting, pls advise if anyone to recommend?
  • 2 months later...
Plumbing Work
Wet Work
Regards
Under what situation will new tiles be required for replacement?
Currently, the toilet tiles are in quite a good condition.
By the way, if the price same for residential and commercial unit?
Thanks!
  • 3 months later...
Things done
hack away the floor
do the waterproof
Can you please pm me the contractor details. I need to do some renovations to my hdb toilets
Thanks
