4 Room Resale (103 Sqm)
Our intention:
- hacking only kitchen & 2 toilets (wall + tiles)
- overlay supreme laminate in 3 bedrooms & living
- plaster whole house, walls & ceiling
- hot/cold stainless stain for whole house
- kitchen cabinet
- 14.5 ft wardrobe
To hack existing floor & wall tiles at kitchen, 2 toilets and discard debris & haulage services - 1,600
Supply sand - 500
Dismantle & discard existing whole house cabinet - 360
To hack existing skirting ****, store & 3 bedrooms, includ make good affected area - 350
To supply & lay laminate floor board c/w skirting ****, store & 3 bedrooms ($4 psf, supreme) - 4,300
To supply & apply waterproofing membrane for kitchen & 2 bathroom flooring - 180
To supply and lay floor tiles at kitchen (300 x 300, $2.80 psf) - 1,460
To supply & lay wall tiles on exposed area only, no wall tiles behind kitchen cabinet (300 x 450, $2.70 psf) - 2,900
To construct 8" ht concrete kitchen cabinet base c/w tile skirting - 380
To supply & install 1 set of flat type rubbish chute at kitchen - 180
To supply & lay floor tiles at kitchen bathroom (300 x 300, $2.80 psf) - 450
To supply & lay wall tiles at kitchen bathroom (300 x 450, $2.70 psf) - 1,480
To supply & install 1 set of PD bi-fold door c/w pvc panel at kitchen bathroom - 320
To run 2 nos of new stainless steel water piping at kitchen bathroom- 270
To run inlet & outlet pipes for wash basin at kitchen bathroom - 80
To run inet & outlet pipes for shower area, include installation of shower headset at kitchen bathroom - 120
To provide labour to install water heater at kitchen bathroom - 90
To provide labour to install WC bowl at kitchen bathroom - 100
To supply & lay floor tiles at mbr bathroom (300 x 300, $2.80 psf) - 480
To supply & lay wall tiles at mbr bathroom (300 x 450, $2.70 psf) - 1,680
To supply & install 1 set of PD bi-fold door c/w pvc panel at mbr bathroom - 320
To run 2 nos of new stainless steel water piping at mbr bathroom- 370
To run inlet & outlet pipes for wash basin at mbr bathroom - 80
To run inet & outlet pipes for shower area, include installation of shower headset at mbr bathroom - 120
To provide chemical washing for whole house flooring - 180
Whole house wall & ceiling plastering smooth - 1,600
Paint whole house ceiling & walls using ICI paint, including door frames - 1,350
To re-varnish & re-lacquer existing doors at 3 bedrooms, store, and main door includ new door lockset - 420
To supply & construct L box to box up water pipes **** - 380
To fabricate & install storage tall unit at kitchen for oven & microwave - 450
To fabricate & install tall unit to box up sewerage pipes at kitchen - 300
To fabricate & install top (12.5ft) & bottom (12 ft) kitchen cabinet using solid ply door in laminate finish c/w ABS tramming & 1 set 2 layer dish drainer without door at kitchen - 3,150
To fabricate & install solid surface worktop for kitchen cabinet - 1,000
To fabricate & install wardrobe with casement doors (14.5ft) - 3,100
Total: $30880
Missing:
- Sliding door at kitchen,
- lourve windows @ 2 bathrooms,
- shower kerb @ MBR bathroom,
- kitchen window replacement,
- removal of cornices for whole house, altar in storeroom, pillars in living room, mortar base, stove & sink support, aircon unit & compressor
- L box for 3 bedrooms
- installation of cooker & hob
- tiles at step at stairs at main door
- electrical works
We intend to do for now
- kitchen cabinet
- 14.5 ft wardrobe
Here's a third quote we got from contractor
Supply sand - 500
Total: $30880
Missing:
- electrical works
I see that your contractor quote you laminate flooring.
Both laminate Flooring and solid wood flooring have their pros and cons but usually if you do not mind paying more, solid wood is the preference to compressed wood. Beside solid wood flooring allow you to do refurbishment (restoration by grinding the surface), which can be seen as a better long term investment.
If you are considering wood (e.g. parquet) flooring for your house, I can provide recommendation which you can save some money by working directly with the wood flooring specialist (reduce middle man markup).
If you are interest, you can email me at alfred.cheong@live.com
- kitchen cabinet
- 14.5 ft wardrobe
Supply sand - 500
Total: $30880
Missing:
- electrical works
From the quotations which i received for my renovation. The most expensive Bi-Fold door that was quoted to me is $260, the range is $200-$250, but you were quoted $320.
Of course we may not be comparing an apple to an apple, so pls check if your apple is worth the pricing :drunk:
Also, i noticed that you may have overlooked the base support for Fridge and washing Machine?
  • 1 month later...
Oh feel so sad for you must hv kanna chop..chop... like Robert
  • 2 months later...
Oh..pitiful
