shuseido
Is This Renovation Quotation Reasonable? Pls Help.
Hi all, I have received below quotation from 1 of my shortlisted contrator. Need you guys' expertise to help to check whether this quotation is reasonable. Thanks million in advance!!
1. Fabricate and install 5ft vanity cabinet & mirror in laminate finish. - $1100
- Top and bottom laminate vanity cabinet with lighting pelmet
- Wall to wall mirror
- laminate surface vanity worktop
2. Fabricate and install master room 6ft sliding wardrobe in laminate door finish. - $1500
- Additional $350, if change the doors to mirror type.
3. Supply & install one panel of conceal wooden sliding door at kitchen entrance. - $1850
- 8 ft door with tempered glass at the middle.
- Existing partition will be hacked down.
4. Supply & paint whole house wall & ceiling using ICI paint (4+1 colors). - $1100
- Include paint prime sealer for whole unit ceiling and fibre board works
5. Supply & paint door frame, doors, pipeline, gate, window grills using gloss paint. - $200
Should look for few more id to compare...
yeah i agree. maybe you can try out the very famous uncle here in RT or my ID lor. wat you think?
