mgbm
Need Help On Timber Flooring
Hi all,
just had my timber flooring for my rooms done.
Found that there some tiny lump protuding and was told by the contractor it is because of the nail and is normal?
Is that true or it is a defect that need to be rectify.
Hi all,
Hi there,
From what i understand, it is not normal to have protusion caused by nails as timber flooring is laid using adhesive. nails are used only if a layer of plywood is required to provide a smooth base but even then, the nails are supposed to be flushed with the plywood. Anybody correct me if i am wrong, this seems to be more of a defect.
