Chongchong
Glass Works Quote
Hi, there.
I am getting alot of help from this forum already. Therefore, may I get you to share your experience for our ID's glass work quotation?
1. To supply & install (L3400mm*Ht900mm equals to 11.15ft*2.95ft) frosted glass wall c/w frameless glass door 10mm thick clear mix with frosted glass 2 fix panel & 1 swing door at study area S$2200
Is it calculated S$2200/11.15ft, so the psf is S$197psf? Please advise. Is it expensive?
Do you know the market rate for clear glass?
2. To supply & install (L1500mm*Ht1800mm) showerscreen c/w clear tempered glass 1 swing & 1 fix panel at MBR?
Do you know the market rate ?
Thanks all for your kind sharing.
