goodman123
Horizontal Or Vertical Storage Heater You Prefer And Where U Locate It
Just curious for those bros that had purchased the storage heater, which type of the heater u purchased? Those horizontal type of vertical type? And usually u put this storage heater at where? Service balcony or common bathroom or ????
Please advise. Thanks.
Horizontal / Vertical is mainly determined by the space you have for mounting your water heater. For example, if you have a bathroom with high ceiling and you want to mount your water heater above your bathroom's false ceiling, in this case you should select a horizontal heater for mounting so that your false ceiling can be higher. On the reverse, if you had chose a vertical heater, your false ceiling may have to be lower due to the vertical heater that take up more height space.
Mine is a horizontal heater. Installed in the common bathroom. There is a false ceiling installed to conceal the heater
