Minnie
Anyone Pls Help To Comment On This Quotation
Hi, pls comment on this quotation for 4rm 7yr old resale 90sqm. This quote is from designer, but i feel that they're more of contractors..
I know nuts on reno. Are there any other cost that should be in as well? I think electrical work? How much will electrical cost?
1) Professional design consultation
2) Propose furniture layout plan F.O.C
3) Detail perspective drawings F.O.C
4) Materials & colour scheme proposal F.O.C
B) DEMOLITION WORKS :-
1 To dismantle exisitng TV console at kitchen $80.00
2 To dismantle 1 set of wardrobe at master room $180.00
3 To dismantle exisitng kitchen cabinet at kitchen $180.00
4 To dismantle exisitng sanitery wares for 2 bathrooms $80.00
5 To hack off exisitng vanity at master bathroom $60.00
6 To dismantle exisitng headbioard at master room $60.00
7 To hack off exisitng flooring and all bases at kitchen $250.00
8 Supply labour to uplift sand, cement & materials to unit. $350.00
9 Clearing off debris under whole renovation. $250.00
C) MASONRY WORKS :-
1 To supply and overlay ceramic/homogenous wall tiles for 2 bathrooms wall $2,450.00
2 To supply and overlay new homogenous floor tiles for 2 bathrooms $800.00
3 To do water proofing for 2 bathrooms floor $120.00
4 To construct drop/shower kerb for 2 bathrooms shower area $180.00
5 To supply labour and material to plaster smooth onto exisitng wall tiles at kitchen except those behind kitchen cabinet and glass backing $550.00
6 To supply and lay new homogenous floor tiles for kitchen floor $950.00
7 To do water proofing for kitchen flooring $120.00
8 To construct cabinet base with side tiles $180.00
9 To construct fridge base with tiles at kitchen $90.00
10 To construct washing machine base with tiles at kitchen $90.00 (Note - tiles prices for kitchen and 2 toilets $3psf)
F) PAINTING/Conices WORKS:-
1) Supply & apply original ICI Dulux or Nippon paint to all internal walls & ceilings.(Max 8 colours)(Pricing including painting kitchen wall ) $1,250.00
2) Supply & apply ICI gloss paint to all water piping, gates, doors, door frames & sewage pipe. $180.00
3) Supply and seal up diamond shape cornices at foyer area $80.00
4) Supply and flush up exisitng L-box area with false ceiling at dining room $350.00
H) PLUMBING WORKS :-
1 Whole house piping change to stainless steel pipe except those along main bedroom piping $550.00
2 Supply labour to install basin & pedestal WC @ 2 bathroom. $320.00
3 Supply labour to install accessories @ 2 bathroom. $80.00
4 Supply labour to install 2 nos of shower sets for 2 bathroom $80.00
5 Supply and install washing machine tap $35.00
6 Supply labour to install 2 nos of spray jets $40.00
7 Supply labour to install 2 nos of storage water heater $240.00
8 Supply labour to install 1 nos of kitchen sink and tap $90.00
9 To run 2 nos of hot piping for shower area for 2 bathrooms $200.00
I) MISCELLANEOUS:-
1) Supply & lay protection sheet. $180.00
2) Clean up whole unit with chemical. $220.00
J) Custom Made Built-in Furniture Kitchen Area
1 Design & fabricate top and bottom L-shape kitchen cabinet in laminate finish c/w 04 sides ABS $3,150.00 trimming swing
doors,choices of drawers, cutlery tray & designer handles (L- 30ft).
2 Supply and install solid surface work top for kitchen cabinet at kitchen (L-15ft) $1,050.00
Living/Dining room
1 To design and fabricate suspended TV console finish in laminate **** room (L-6ft ) $720.00
2 To supply and paste new laminate over exisitng cabinet at house hole shelter and wall feature at TV console area (Est-L-
15.5ft X Full ht)(pricing including dismantle exisitng glass at recess in and flush up with plywood finish in laminate )
$2,100.00
Bedroom area
1 To design and fabricate full ht built in wardrobe finish in laminate c/w sliding doors for master room (L-6ft X Full ht)
$1,440.00
2 To design and fabricate full ht built in wardrobe finish in laminate c/w sliding doors for bedroom 3 (L-4.5ft X Full ht)
$1,080.00
3 To design and fabricate 6ft ht wall feature finish in cushion bed head board at master room (L-7.5ft X H-6ft ) $1,500.00
Bathroom area
1 To design and fabricate suspended vanity cabinet finish in laminate at master bathroom (L-4ft) $440.00
2 To supply and install solid surface vanity top for master bathroom (L-4ft ) $320.00
3 To custom made full length mirror at master bathroom (L-4ft X H-800mm) $120.00
Aluminium,Glass,Timber & Wrought Iron Works
1 To supply and install 10mm thick clear tampered glass shower screen c/w swing door for master bathroom (L-1.5m X H-
1800mm) $520.00
2 To supply and install top hung 10mm thick clear tampered glass sliding door for kitchen entrance (L-3.5ft X H-7ft) $680.00
2 To supply and install 6mm thick tampered spray paint glass for inbetween kitchen cabinet at kitchen (L-15.5ft X H-2.5ft )
$700.00
3 To supply labour and material to sand and revanished exisiting parquet flooring and skiritng for 3 bedrooms $600.00
4 To supply labour and material to stain and revanished doors for 3 bedroom and 2 bathrooms $375.00
5 To supply and install full ht black mirror at dining room (L-6ft X Full ht) $900.00 6 To supply and install design wall paper
at dining room (L-10ft X Full ht) $650.00
Total Amount : $27,260.00
C) MASONRY WORKS :-
I) MISCELLANEOUS:-
Living/Dining room
$2,100.00
Bedroom area
$1,440.00
$1,080.00
Bathroom area
1800mm) $520.00
$700.00
No one has comments on this quote? Help meeee.....
For your info and best interest, you'll need a few more quotes to compare your prices.
