aspella77
Hinge Failure (screws Sheared Off)
Hi All,
Just wondering if anyone had similar problem...
One of the Three Hinge was affected with Screws being Sheared Off!
Fixing back with new screw is one thing... Just wondering whats wrong?
Thanks....
Brass is non-ferrous, soft material just like aluminum, it breaks off easily.
Post a picture of the original screw, is there any nut on the wooden door?.
Edited by gladyslim
Thanks for the reply...
The original screws were broken with threaded portion inside the door...
Just wondering if my other doors would be affected...
Haiz....
I replaced mine with stainless steel.
Remove one pc as sample and get the stainless steel type from hardware shop.
Buy exactly the same dimension; should be M6 x 12mm, No. 8. @ 15cents a pc.
As for the broke off pc, you need drill a small hole and then enlarge it to about 4mm dia without damaging the nut and use a pointed object like nail to slowly remove the stuck broken screw.
No, the other doors will not be affected so you dont have to worry about that. And just follow what the others said to you about your questions.
_______________
online auto insurance quote
This is quite normal for brass screw.
Chg them to stainless... it will outlast the hinge itself.
Buy them from Daiso .... $2
$2/- for how many pieces?
1 set of door require 64pcs. I only replace a few that broke off.
