cacabi111
Toilets- How To Clean The Drainage Pipes + Detergent For Toilet Floors
Pls help, thanks!
1) my drainage pipe is plastic type (so cant pour hot water), how to clean and unchoke properly?
(moved into resale flat, the pipe is working fine...but can see lots of hair in the pipe)
2) what detergents to use on toilet floors...any that can create suds?
To answer your question.
1) Your drainage pipe is made of PVC not plastic. Able to withstand hot water once in a while. There are different type of choke, too oily... , residue , hair strand.
If you are not afraid of dirty, you have to open the piping cap so as to clear the choke in it.
If you are afraid of dirty, you can buy a bottle "Drain Choke Solution" from the DIY shop. should be less than $10.
2) Toilet floor detergent, if you dun mind the smell... you can dilute the bleach solution with water and wash the floor.
