window8
Renovation Budget For Premium Flat
Hi can i check with those that have purchase premium flat, how much was the renovation cost about?
please advise
40k?
depends on what you are doing....
40k?
I b herring by flat next year
the flooring is done by HDB.
I intent to do the following;
- kitchen cabinet
- feature wall
- hide the bomb shelter
- l-box
- shower screen door for both toilet
- change toilet doors
standard kitchen cabinet will be abt 2.5k
feature wall 1k
shower screen door 1k
the rest I dunno.
These are so far what i see from the quotes I got.
Also depends on materials, and other misc like lighting pts.
feature wall 1k
the rest I dunno.
Thank You 'jtjw' for ur reply
- kitchen cabinet
- feature wall
- l-box
Take this as a guide, it can be more by 10-20% depending on material used.
-Kitchen cabinet top 10ft, bottom 10ft, total 20ft - $2000
If using Blum hinges, prepare to add in another $500
- Solid surface kitchen top, 10ft - $800
If using Corian solid surface is max. $1500
- India, Finland, Norway, Granite kitchen top, 10ft with 60-65mm backsplash, 40mm 45 deg front profile - $1500
If using China granite top, is ard $1000
- Quartz kitchen top, 10ft - $2000-$2900 depend on which models selected
- 6mm coloured tempered glass backsplach, 10ft - $800
Plumbling and electrical work for the kitchen area is ard $400
- Feature wall 6ft, simple design is ard $750
-TV console 6 ft, - $800
- Feature wall for bomb shelter, 6ft is ard $750
- L-box is calculate @$10pfr, if not doing much, is calculate as 1 lump sum.
- 10mm tempered glass shower screen, 1 fix panel, 1 swing door cost $400 each L1.5m x H1.8m
Sliding tempered glass shower screen is $600 each
- Toilet door is depend on brand and material used. Normal Top hung bi-fold door cost $250each, Pd door cost $269-$399each.
Dismantling and disposal of existing HDB toilet door and also make good the surrounding area will cost u another cost ard $400.
:yamseng:
:yamseng:
ThankS' jaskel' - for replying- i guess roughly i hv to put aside $25K
If you are doing quite a bit on fixtures then will be more expensive due to it is make to measure.
also set aside ur about 2K for your lightings, lighting point, cable point (if need to shift) and wiring.
ThkZ For the Advice...
Hi, Guys.
I always heard fellow friends says that, it is always good to keep around $1k to $2k for lighting.
Is that true? What are the other thing that I had to come out with cash during the renovation period. Doing my renovation early next year, so I am recce-ing around =)
Thanks alot.
window8, it would be good to ask around for quotations from contractors....tat would be a gd gauge....
however, as per ur list below and dependent on the material cost (according to wat kind of material u choose), on a safe bet, u need to set aside at least about 25k to 30k....
- kitchen cabinet
- feature wall
- l-box
Hi, Guys.
Thanks alot.
I got mention as above on the lighting part. For advise would be 2K. Things keep increasing but no salary. sigh~~
During renovation period there are a few things need cash -
1) Kitchen
- hob and hood
- kitchen basin
- tap
- fridge
( check the measurement first then ask ur ID/contractor to do the measurement, if you want to do base for your fridge. )
- washing machine and dryer (if needed)
( check the measurement first then ask ur ID/contractor to do the measurement, if you want to do base for your washer and dryer. )
2) Air-con ( must know what system and how many compressor you want. Eg . system 4 for all the rooms and one for the living room)
Others like living room and bedroom all depends on the design which you liase with your ID/contractor. :paint:
Do remember that if anything which is required to build then you need to get it first.
Hi window,
have u source for quotations?
so far for mine is roughly around 18k for most of the firms I asked around for works like
false ceiling and L box
living rm partition and full height shoe cabinet
kitchen (the usualy stuff) (it normally measure up to 24 ft with solid top at abt 3 - 4k)
mbr wr + bedframe with storage + low cabinets at window side + 2 side table
2 toilet glass shower screen
window grill whole house + SY window
tv cosole + feature wall
painting
plumbing + misc
The material they provided are quite ok, unless u want top graded material.
1) Kitchen
- hob and hood
- kitchen basin
- tap
- fridge
Ok, I see. Intend to buy bit-by-bit. So son't need to outlay so much cash when the time comes.. . .
Thanks anyway for yr suggestions.
By the way, anyone had any idea what other item does BTO flats comes with apart from the doors which I bought and the done-up flooring. . .
I was wondering does it comes with sink, taps and etc.
How about toilets, we install our own sink too?
Edited by hengmenghwee
