therat
Can Advice On My Quotation
Hi forumer,
Need some advice on my quotation.
Which area I was over-quote.
My unit is a 4rm 92sqm2 resale flat.
Demolition Work
Provide labour, material & tools to hack / dismantle
- Floor & wall tiles at 1 bathroom $600
- existing sink & stove support $500
- existing kitchen cabinet $100
- existing wardrobe - $150
- Haulage & debris fee - $500
Masonry Work
Provide labour, material & tools to lay/construct
- kicthen cabinet base c/w side tiles finishing $200
- 300 x 600mm floor & wall tiles at bathrooms (tiles $2.80, 280 qty) - $1624
- first layer water proofing membrance $120
- 3 in 1 water proofing cement screeding at bathrooms $120
Plumbing Work
Provide labour, material & tools to run / install copper piping for bathroom $750
- WC / toiler bowl
- basin & tap
- Bathroom accessories set
- water point c/w min spray
squatting pan to sitting pan $200
Painting
Painting for the whole housing using Nippon 5000, ceiling are common white emulsion paint only ( 1 white + 4 colour) $1200
painting for 4 door & door frame - $240
Electrical Work
2x 13 amp single power point $120
2 x 13 amp double power point $150
20 amp heater point $100
Carpentry Works
Design & fabricate top and bottom kitchen cabinet (31 ft) $3100
- solid plywood
- laminate finishing
- ABS trimming for all door and drawers
Supply and install solid surface top (17 ft) $1190
Design and fabricate casement wardrobe with laminate finishing for bedroom 1 (6.5ft) $1300
Other
Supply & install bi-fold door for 2 toilets $400
Provide labour to change door lock (5 locks) $150
Chemical wash and general cleaning for whole house (3rm) $200
supply and lay floor protective covering for whole house $150
Supply and install 1 stainless steel chute $150
Supply & install painted glass backing for kitchen cabinet (43 ft) $774
What do you all think about the above quote?
