jeffcraze
Address Of Harfary
Hi there.. Can anyone provide me with the address of Harfary, the place highly recommended in the forum for tiles? Would like to go take a look at the tiles range there.. ;) Thanx! :)
U can get their address by using yahoo or google search, so hardworking a bit.... ;)
Thanx boatgal for providing the address! :D
15 Defu Ave 1 also have while their warehouse is at Defu Lane. Balestier is their branch.
is it acceptable to ask my ID to use Hafary tiles? should i ask source of tiles my ID is using?
First, did u select the tiles or your ID select it for you?
all I have right now is the quote from ID... doesn't say source of tiles... below's an extract from the quote
Supply labour, tools & material to lay 300mm x 600mm wall tiles for kitchen ( Up to ceiling height ) $3,500.00
Supply labour, tools & material to lay 300mm x 600mm non-slip homogenous floor tile for kitchen $1,100.00
Supply labour, tools & material to lay water-proofing membrane ( non-string grout, 104 quick seal, water-proof cement & chemical cement ) for kitchen flooring $300.00
Didn't indicate what is the max. limit for the price of tiles u can choose? U can choose any company tiles, just bring the ID along can liao.
Thanks much jaskel, i'll try your suggestion :)
