htng
Kdk Low Ceiling Fan A11sy
have anyone been using A11YS - does it spoilt easily? i have no confidence in remote control fan after having bad experience with Elmark (3 ceiling fan broke down just after 1 year warranty).
pls advise if A11YS more durable? in term of remote control / sensor? i heard my friend been using KDK remote control ceiling fan for 4 year+ and none of the component spoilt until now (but it's not A11YS model). desperate looking for durable ceiling fan for hdb bedroom.. :(
I'm thinking of installing KDK ceiling fan in my house but recently, I've went to someone's house who have installed KDK A11YS. Speed 3 can only feel the wind under the fan. If you a bit away from the fan (about 0.5m or lesser), you cannot feel the fan anymore. The house doesn't have any false ceiling or L-box. Probably it's better to get other KDK models.
Edited by buibui
I have 2 kdk stand fans and 1 table fan in my parent's house, have dropped them, scratched them pushed them around far too often and they are still going strong -_-"
I think they outlasted the renovations.
Personally i feel for ceiling fans speed 1 should typically be only for sleeping or really cold weather when you need a bit of air circulation.
If all 3 speeds are so windy then no variation le mah. =)
Cheers,
Jia Jun
i have 3 of the baby fans in each of my bedrooms, and i feel a chill at speed 2 already.... best purchase for my house reno. Frees up the floor space, yet cut down the aircon bills.
i think the ceiling fan has to be a certain distance away from the ceiling in order to be effective right ? thats according to KDK website
How to choose a ceiling fan?
Choosing a ceiling fan location
Fan should be placed in the centre of the room, unless the space is too large and require 2 or more fans for better airflow. For safety reasons, we recommend to avoid installing a fan directly above a bed.
Depending the room size
A large bedroom or living room would require a large ceiling fan (blade length: 56 to 60 inches) to move the air effectively. For smaller room, fan blade length between 44-56 inches will be adequate. However, the size of the fan also depends on individual needs.
Mounting measurements
A ceiling fan needs to be 2.3 – 2.8metres, from the floor, with the blade tips at least 0.6metres away from walls or tall furniture. If you're using more than 1 ceiling fan, do ensure to install them 3 metres away from each other (distance between the downrod).
Ceiling height
Room with high ceiling requires a more powerful fan to promote air circulation. Ideally, a ceiling fan should be at least 2.3 – 2.8meters from the floor.
In situations when the ceiling is extremely high, extension fan down rod can be used. A general formula for calculating down rod length is to take the ceiling height less 2.3 – 2.8metres. Example, if your ceiling height is 3.65metres, after deducting 2.3metres (from the floor), the down rod required is 1metre long.
