junior
What The Difference Between Id Firm And Contractor With In-house Designer
Plase Advise ..
Think ID firm is the ID itself is contractor and contractor with in-hse designer is.....u should knw wat i wanna say lah.
HAHAH ... DUN UNDERSTAND ...
you mean in Singapore? Then the answer is no different....or not, very depending on the designer in the house.
in id firm:
the id who design for you very depending on their contractor to complete the work
in contractor firm:
the contractor is very depending on their id to advice to complete the work
very mix up right? so the best is to find someone who is designer & contractor itself ;)
btw, if you come across someone who is not designer nor contractor, but a consultant, then very much good luck to you :jawdrop:
