thx888
One Stop Home Theatre / Music Solution
Hi Scott,
Am I allowed to put the speaker beside or on top of the sub (in a 2.1 system)?
Thank you
Hi Hentamkings,
As for your above question , there is no right or wrong where to place our speakers , it is just down to trrying out for the best location.The general rule is to place your speakers equal distance between them, can check out AVS FORUM for more indepth information. It is best to place your speakers on a proper speaker stands . Reason is to reduce unwanted vibration and placing on the top of the subwoofer is a no no . With proper placement of the speakers will give better imaging and sound as compare if you place on top of the subwoofer . Hope that answer you question.Thank you.
Hi Hentamkings,
Thank you Scott. so there should be no issue if I place the speaker beside the sub?
Hi thx888, can suggest a HT setup for upmost of 2.5k, for a pure entertainment room of 2.75metres X 4.1metres? this setup will be used mainly for movies and a little gaming ba, and maybe 20% music.. thanks!
Hi BlurRhino,
Pls pm me or call me at 97894630 for further dicussion. Thank you.
Hi Scott,
I am looking at Stereo system, mainly on Marantz.
Other than Power and tunner function of CR502 compare to "CDx003 + PMx003"....what other different?
Currently i am not sure to get CR502 alone or the CPD + Amp. Is the sound quality a great diff?
Will put this system in one of the bed room, driving bookshelf speakers.
Pls help. thanks.
Hi Scott,
Pls help. thanks.
Hi Pckee,
Just PM you for some suggestion.
Hi Pckee,
Hi Phantom,
Currently the SVS models at KEC :
Small box
1) SB 10 NSD ( $828) depending on the finish
2) SB 12 NSD ($1 350 ) depending on the finish
3) SB 12 Plus ($2 338)
4) SB 13 Plus ( $3,299)
Big box
1)PB 12 NSD ($1099)
2)PB 12 PLUS ($2250)
3)PB 13 Ultra ( $3099)
Cylinder
1)PC 12 NSD ($1099)
2)PC 12 PLUS ($1850)
3)PC 13 Ultra ( $2750)
Please kindly take note , there would be a price increase due to the new sledge amp , pls kindly check kec websie for future update. Thank you.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • advertisement_alt
  • advertisement_alt
  • advertisement_alt
