volcom
Bosch Tabletop Dishwasher
Hi. I've bought Bosch tabletop dishwasher but I've no more tabletop space in the kitchen so thinking of putting it on a rack drilled to the wall in service balcony. This is the model SKS60E02EU, white compact dishwasher: http://www.bosch-home.com/sg/products/dishwashers/compact/compact/SKS60E02EU.html?source=browse
PROBLEM is, I can't find any suitable rack that can support it's weight. Tried IKEA, Howard storage and Self-FIX but can't find any. So appreciate if someone can point me to the right direction :)
hi volcom, sorry i cannot help you with your problem. but can i check if you bought this in Sg, how much did you pay for it and do you find it useful so far? thanks!
Looks like you'll have to DIY a solution.
What you need are L-shaped wall brackets like those on the right in this pic:
Then you'll need to mount them onto the wall with anchor plugs.
The bottom of the plug expands as you tighten the bolt. So all you need to do is to drill a large enough hole, mount the bracket, put the anchor plug through it, and tighten.
If the bracket is long enough, and the bottom of the dishwasher is flat, then you can just rest it on the bracket. If the bracket is too short to support the entire base of the dishwasher, you might want to get some wood and make a shelf for it.
My neighbourhood hardware store has both the bracket and anchor plugs. Unlike the Ikea shelf brackets, the ones they sell are solid metal and big.
