donster 0 Report post Posted August 22, 2012 Anybody has any contact for repair of tempered glass shower screen?My shower glass door is those swing type which is hinge on the wall by 2 hinges. One at the top and one at the bottom.It is peeling off from the wall when I try to open the shower screen door. I tried to screw the hinge tightly to the wall. But it didn't help.Thanks for reading this post. Share this post Link to post Share on other sites
casa 0 Report post Posted August 23, 2012 Anybody has any contact for repair of tempered glass shower screen?My shower glass door is those swing type which is hinge on the wall by 2 hinges. One at the top and one at the bottom.It is peeling off from the wall when I try to open the shower screen door. I tried to screw the hinge tightly to the wall. But it didn't help.Thanks for reading this post.I don't think its the hinges faultIts more like the wall plug that hold the hinges to the wall is looseIf screwing can't be tighten and its loose that's it maybe offset the hinges position Share this post Link to post Share on other sites
yoongf 11 Report post Posted August 23, 2012 Wall plug is the problem.Use a thicker wall plug, or a fatter screw, or a longer screw + wall plug. Share this post Link to post Share on other sites
donster 0 Report post Posted August 23, 2012 Wall plug is the problem.Use a thicker wall plug, or a fatter screw, or a longer screw + wall plug.Thanks yoongf for your suggestion. If I change the wall plug and use a fatter screw, I will need to dismantle the shower screen first. I'm afraid I will drop and break the shower screen while changing. Is there any method of taking down the shower screen door? I saw some professional use the vacuum handle. Where can I get those? Any other precaution that I should take to avoid breaking the shower screen glass door? Share this post Link to post Share on other sites
donster 0 Report post Posted August 23, 2012 I don't think its the hinges faultIts more like the wall plug that hold the hinges to the wall is looseIf screwing can't be tighten and its loose that's it maybe offset the hinges position Thanks casa. It could be the alignment is out. If I want to get professional help, any contacts? Share this post Link to post Share on other sites
casa 0 Report post Posted August 24, 2012 Try get the pro/handyman to do yhe jobAs u know the glass is heavy w/o proper tooling u unable to do it yourselfChk classified ads for handyman Share this post Link to post Share on other sites
