aeiousg
Wooden Sliding Door Repair (Top Roller)
I have this wooden sliding door as toilet entrance door misaligned and cannot close properly. The roller is on the top but there is nothing can be done as it seems covered up. If you know any contractor who provide service to this type of door, pls do let me know. Thank you!
Oops... Look like i can't attach picture here...
If you can provide some pictures,i may be able to tell you what are the things
thats need to be done.
Here the pictures:
IMG_3552.JPG?psid=1[
IMG_3553.JPG?psid=1
Edited by aeiousg
Here the pictures:
IMG_3553.JPG?psid=1
Always a challenge to change this type of rail and rollers.
Door is heavy with the glass.
1.Need to unscrew the whole alluminium rail mounted to the top.
2.slanting and slide out the sliding door together with this rail and roller.
3.take existing roller as sample to buy new one,must make sure it fits in the rail
4.if bottom guide spoil,change also
Its always easy to say than done LOL.
Still take time to get someone to fix it. As there are so many units here (not HDB) with the same design, it would be potentially coming more opportunity to receive such service demand (good business $$ LOL), if can fix mine "sui sui", I may consider recommend to the management...
Hi again,
For your case i think you may call the management and ask the developer to recommend.
The developer uses all the same imported sliding mechanism and easier to get and fix by their own people
BUTTT....usually they will ask you to settle yourself by calling you own contractor.....reason being($$$$$$ in their
pocket,too heavy to come LOL.....Joking lah!)
Dont think Developer will entertain this kind of wear and tear repair. They r more into projects. Thats y better to look for your own contractors.
