santa007
Inter-Terrace Renovation
Hi guys,
After 3 months of renovation, house reno is almost complete. Just to share my quotation given by my contractor.
1. Hacking / Dismantling Works
1. To supply labor & equipment to hack / dismantle & clear the
following items :
Driveway / Garden
· Driveway tiles
· Pond structure & related works
· Side wall under the staircase
· Staircase side wall tiles
1st floor
· Entrance store cabinet
· Main door & frame
2nd floor
· Dining room existing wall feature
· M/S ornamental grilles
· Bedroom 1 toilet
- floor & wall tiles
- All sanitary & fixtures
- False ceiling
- 1 nos. door & frame
· Kitchen
- Kitchen floor & wall tiles
- Wall between Dry Kitchen & We Kitchen
- Kitchen concrete sink / stove support
- Kitchen false ceiling
from page 1 ………
following items :
3rd floor
· Family room ceiling decor
· Bedroom 3 & 4 (Identical – Mirror image)
- Part water damage parquet flooring
- Existing sliding doors to balcony
Toilet
- Wall & floor tiles
- All concrete structure
- Fixtures & all sanitary wares
- False ceiling
- 2 nos. doors & frames
4th floor
· Master Bedroom (M/B)
- Existing balcony doors
- False ceiling features
- Part parquet flooring outside the toilet
M/B Toilet
- Floor & wall tiles
- Bathtub & support structure
- False ceiling
· Balcony
- Part existing roof for alteration purposes
- Sliding doors
- Enlargement of wall for natural light
· All cabinetry works from 1st –4th floor
2. Masonry Works
2.1 Driveway / Garden
2.1.1 To supply labor & materials to lay 300 x 300 / 600 granite slabs.
2.1.2 To supply labor & materials to tile up pond riser.
2.1.3 To supply labor & materials to make good the flow of water for
the cut-off driveway drain using chemical cement screed.
2.1.4 To supply labor & materials to slab over existing cut-off drain
across driveway / car porch.
from page 2 …….
2. Masonry Works
2.1.5 GMS drain grating (To fabricate & install)
- To replace existing plastic drain grating with gms heavy duty
drain grating along boundary wall.
- To fabricate & install gms granite slab tray for drain across
driveway.
2.1.6 Staircase
- To supply labor & materials to make good walls affected by
demolition works below staircase.
staircase side wall tiles.
2.2 Kitchen
2.2.1 Top Up
To supply labor & materials to top up the wet Kitchen floor level
with the existing dry Kitchen floor level.
2.2 Kitchen
2.2.1 To supply labor to lay homogeneous / ceramic floor tiles (provided
by the owner), c/w water-proofing works to the new Kitchen.
2.2.4 To supply labor to install ceramic wall tiles (provided by the
owner) to ceiling height for the whole Kitchen.
2.2.5 To construct concrete Kitchen cabinet, refrigerator & washing
machine bases.
2.3 2nd floor Bedroom 1 Toilet
2.3.1 To supply labor to lay homogeneous / ceramic floor tiles (provided
by the owner) c/w water-proofing works.
2.3.2 To supply labor to install ceramic wall tiles to ceiling height.
(Tiles to be provided by the owner)
2.3.3 To construct 1 no. shower kerb in tiles finish.
2.4 3rd floor Bedroom 3 & 4
2.4.1 To supply labor & materials to top up the existing balconies floor
level with that of the existing parquet flooring c/w cement screed
to cater for new floor board.
2.4.2 Toilet
- To supply labor to lay homogeneous / ceramic floor tiles
c/w water-proofing works. (Tiles to be provided by the owner)
- To supply labor to install ceramic wall tiles to ceiling height.
- To supply labor & materials to top up toilet flooring to cater for
sunken bath area.
from page 3 …….
2. Masonry Works
2.5 M/B
2.5.1 To supply labor & materials to make good walls affected by the
removal of the M/B door / frame.
2.6 M/B toilet
2.6.1 To supply labor to lay homogeneous / ceramic floor tiles c/w
2.6.2 To supply labor to install ceramic wall tiles to ceiling height.
2.6.3 To supply labor & materials to top up toilet flooring to cater for
sunken bath area.
2.7 M/B balcony
2.7.1 To supply labor & materials to level the M/B balcony floor with
the existing M/B floor level inclusive of cement screed.
2.7.2 To supply labor & materials to construct new red brick balcony
parapet walls to cater for new roof works c/w cement screed.
2.7.3 To supply labor & materials to make good area affected by the
enlargement of the natural light opening by the staircase.
2.8 To supply labor & materials (inclusive of marble) to make good
Main entrance wall & flooring affected by the removal of main
door frame.
2.9 Bedroom 2 external utility slab
2.9.1 To supply labor, tools & materials to clean up the existing slab
area, & to cement screed with chemical cement c/w water-proofing
works including the improvement of water flow.
3. Floor Finishes
3.1 Existing marble flooring
3.1.1 To supply labor & equipment to polish 1st floor existing Living
room & 2nd floor Dining marble flooring.
3.2 Existing parquet flooring
3.2.1 To supply labor, equipment & materials to sand & varnish the
existing parquet flooring to the following areas :
· 2nd floor Bedroom 1
· Bedroom 2
· 3rd floor Family room
· Bedroom 3
· Bedroom 4
from page 4 ……..
3. Floor Finishes
3.3 To supply labor, equipment & materials to re-varnish existing
staircase inclusive of the landing areas.
3.4 Making good damaged parquet flooring
3.4.1 To supply labor & materials to make good damaged parquet
flooring due to the removal of M/B timber door frame.
3.4.2 To supply labor & materials to make good water damaged
parquet flooring due to the removal of the parquet.
3.5 Simulated timber vinyl floor boards
3.5.1 To supply & install the vinyl floor boards to the flowing areas :
· Bedroom 3 & 4 new Study area
· M/B top up balcony area
3.5.2 To supply & install water-proof vinyl floor board to overlay the
main entrance ceramic staircase.
4. Miscellaneous
4.1 To supply labor & materials to install new conceal hot / cold
water copper piping to the following areas :
· 2nd floor Dry / Wet Kitchen (inclusive of washing machine)
· 2nd floor Bedroom 1 toilet
· 3rd floor Bedroom 3 & 4 toilet
· M/B toilet
4.2 To supply & install the following items
(labor only for all sanitary items) :
4.2.1 Kitchen (Wet / Dry)
· 1 x S/S double bowl Kitchen sink c/w mixer tap
· 1 x Washing machine tap
4.2.2 Kitchen toilet
· 1 x Pedestal WC (White)
· 1 x Wall hung wash basin with cold water tap
· 1 x Mini shower spray
4.2.3 2nd floor Bedroom 1 Toilet
· 1 x table top wash basin with mixer tap
· 1 x Mixer tap c/w shower set
· 1 x Central heater (provide by owner)
· 1 set tempered glass frameless shower screen
from page 5 ……..
4. Miscellaneous
4.2.4 3rd floor Bedroom 3 / 4 Toilet
· 1 set L-shape tempered glass frameless shower screen c/w
2 panels corner sliding doors
4.2.5 M/B Toilet
· 1 x Table top “square” wash basin with mixer tap
4.3 Plaster False Ceiling
4.3.1 To supply labor & materials to seal-up the Dining / M/B ceiling
with plaster board after the decorative ceiling is removed.
4.3.2 To fabricate, supply & install plaster false ceiling to the following
areas :
· M/B toilet (inclusive of 1 access panel)
· Bedroom 3 / 4 toilet (inclusive of 1 access panel)
· Bedroom 1 toilet (inclusive of 1 access panel)
· Kitchen both dry & wet area (inclusive of 1 access panel)
· M/B Balcony
4.3.3 To supply labor & materials to repair damaged existing ceiling
due to re-position of existing lamps & other works.
4.4 Windows (To supply & install)
4.4.1 To fabricate & install normal size WPC aluminum casement
windows with tinted glass to :
· Living room (W 975 x Ht1575 mm)
· Bedroom 2 (W1000 x Ht1500 mm)
· Bedroom 3 (W1500 x Ht1650 mm)
· Bedroom 4 (W1500 x Ht1650 mm)
· M/B Balcony (W 4925 x Ht 600 mm)
from page 6 ………..
4. Miscellaneous
4.4.2 To fabricate & install WPC aluminum top hung windows with
frosted glass glass to :
· Bedroom 1 toilet (W1000 x Ht 825 mm)
· Bedroom 3/4 toilet (W 775 x Ht1000 mm)
4.4.3 To fabricate & install WPC aluminum lourve windows for :
· Bedroom 1
- (W1000 x Ht1000 mm)
- (W 575 x Ht1000 mm)
4.5 Roof Works
4.5.1 To fabricate & install M/S hollow section support structure for the
new additional roof from the M/B balcony area inclusive of the
following :
· Installation of clay roof tiles
· Installation of aluminum sheet
· Flashing works for the roof
4.6 Trellis (Driveway)
4.6.1 To fabricate & install M/S hollow section structure for the creation
of trellis to the following areas inclusive of tempered glass top :
· Driveway (W3550 x D4200 mm)
· Staircase (W2525 x D2250 mm)
4.7 Auto Gate
4.7.1 To supply & install 1 set conceal motorized auto gate system for
the existing gate c/w remote control.
4.7.2 To supply & install the following works for the auto gate :
· 1 x 15amp isolator to be place at the external pillar
· 1 x Remote hard switch for the Living room
4.7 Dining Room
4.7.1 To supply & install 1 set “Invisible Grilles” for the railing area.
4.7.2 To fabricate & install full height clear glass mirror in replacement
of the previous wall feature.
4.8 Mosquito Netting
4.8.1 To supply & install magnetic screen mosquito netting to :
· M/B Balcony (W4925 x Ht 600 mm)
4.8.2 To supply & install casement type netting for Backyard gate.
from page 7 …….
4. Miscellaneous
4.9 To supply labor, equipment & materials to administer PU
injection to Bedroom 1window seal area to prevent any further
leakage.
4.10 To supply labor & materials to fill up additional earth to previous
pond area & to re-turf the affected area with cow grass turf.
4.11. To supply scaffolding for internal works (7m height)
4.12. To supply labor & equipment to clean the whole house.
5. Electrical works
5.1 To supply labor & materials to install conceal electrical wiring to :
· Kitchen
- 04 x Lighting point
- 02 x 13amp single power socket
- 03 x 13amp double power socket
- 01 x Remote point for oven
- 01 x Remote point for hood / hop
5.2 To supply labor to re-position existing down-lights
- Based on (15 nos) Lump Sum
5.3 To supply labor & materials to replace Living room high pendant
lamp.
5.4 To supply labor & materials to replace the existing electrical point
covers :
· 20 x Switch cover
· 10 x Single power socket cover
· 04 x Double power socket cover
· 04 x Heater switch cover
· 01 x Dimmer cover
· 04 x Telephone cover
5.5 To supply labor & materials to clean up M/B existing electrical
points after the dismantling of furniture fixtures.
5.6 To lay conceal wiring for SCV cable to the Living room.
5.7 Fan
5.7.1 To supply & install 2 nos. fan point
5.7.2 To supply labor & tools to install 2 nos. fan
from page 8 ……..
Summary Of All Items
1. Demolition / Hacking Works
2. Masonry Works
3. Floor Finishes
4. Miscellaneous Works
5. Electrical Works
Total Lump Sum Equals -------------------------- S$ 72,500.00
For carpentry works: (estimated $40K)
01 Bedroom 1 Wardrobe
  1. 02 Bedroom 2 Wardrobe
  2. 03 Bedroom 3 Wardrobe
  3. 04 Bedroom 4 Wardrobe
  4. 05 a) Master bedroom Wardrobe
    b) Aluminium Frame Sliding Door
    Sub Total :
  5. 06 Bedroom 2 Study Table
    a) Top Cabinet
    b) Lower Study Table
    c) 5mm Clear Glass Table Top Sub Total :
  6. 07 Bedroom 3 & 4 Study Table
    a) Top cabinet @$500/- 2 b) Lower Study Table @$700/- x 2 c) 5mm Clear Glass Top @$400/- x 2 Sub Total :
  7. 08 Shoe Cabinet
  8. 09 a) Living Room TV Console
    b) Glass Doors For Drawers
    Sub Total :
  9. 10 a) Kitchen Top Cabinet
    b) Kitchen Bottom Cabinet c) Solid Surface Top
    d) Glass Backing
    e) Top Cabinet Over Sink f) Bottom Cabinet
    g) Glass Backing
    h) Full Height Tall Cabinet i) Top Cabinet Over Fridge
    Sub Total :
  10. 11 Toilet Cabinets With Solid Surface
  11. 12 a) Painting (External & Internal) b) Scaffolding
After doing my first renovation of this home, some advice to those about to go into renovation:
1. Engage a ID/architect to supervise the project - I tried to save on cost, and got my friend in for the ID and carpentry part. My main contractor is super slack, so ended up i have to come to site almost everyday
2. Always add in 10-20% additional cost to the initial quotation... so that you don't get too surprised with your final bill.
3. Do not pay the full amount of renovation too early.... hold back as much as possible, so that your contractor will rectify all the defects (commonly parquet flooring, roofing work, tiling works, painting works, false ceiling works)
4. Invest on mosquito netting, esp with the rise in dengue fever and the developing concrete jungle in Singapore!
5. Engage a good lighting and water 'specialists' - the 2 guys i used were very good...they came to the house to suggest what type of lightings, water taps, shower heads etc and provided very good after sales service
6. I actually made many trips to Johor Bahru to look at sofas, dining tables, lights, bed frame and mattresss. I ended up buying all in Singapore. JB is definitely cheaper after conversion, but quality is also not as good. Warranty will also be an issue. After making many trips to and fro, I managed to bargain good prices in Singapore. So need good research before buying
Still have lots more tips to share when I find time to post... wanted to post some pictures, but can't seem to be able to copy any pictures...maybe any kind sole can help guide me? ;-)
Thanks
I am thinking of installing mosquito netting for my house. Can u share your contact with me and roughly the cost for the netting psf. Thanks!
Thanks
Agree with u.. even i went through JB n Singapore but ended up buying everything in spore due to qulaity issue n warranty..
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
