New Bto 4-Rm Renovation Quotation
Hi All Expert,
Could you kindly help me see through if this quotation is reasonable?
I am very new in this and my flat is coming either late 2014 or early 2015.
Demoltion & Hacking Works
To provide labour and tools for the following hacking works:
800.00
To hack partial wall at Master Bedroom
To dismantle door and frame at bedroom 2
Masonry Works
To make good doorway between Master Bedroom and Walk-in Wardrobe.
400.00
To construct concrete hollow block wall at former door way at Walk-in Wardrobe.
450.00
To construct concrete shower kerb at Common and Master Bath. (Tiles to be purchased seperately)
600.00
To construct wall panelling with cement boards in cement screed finish ****. (TV wall only)
2,850.00
Carpentry Works
(All cabinet interiors finished wfth white PVC finish, c/w BLUM soft closing hinges, unless otherwise stated.)
Kitchen
To design and construct top and bottom cabinets in laminate finish along Hob side. (L 2600mm)
2,380.00
To design and construct top and bottom cabinets in laminate finish along Sink side. (L 2100mm)
1,960.00
To design and construct full height cabinet with oven compartment in laminate finish. (L 600mm)
980.00
To design and construct top cabinet in laminate finish above fridge. (L 900mm)
460.00
To supply and install solid surface work top to bottom cabinet counters. (L 4700mm)
1,390.00
To supply and install coloured glass backing between top and bottom cabinets. (L 4700mm)
1,050.00
Walk-in Wardrobe
To design and construct casement wardrobe in laminate finish. (L 5700mm)
5,320.00
To design and construct low heght cabinet with glass top and drawer with pigeon hole compartments in laminate finish. (L 1000mm)
750.00
To design and construct sliding door in laminate finish c/w mirror on one side.
1,200.00
Master Bedroom
To design and construct bay window settee with storage in laminate finish. (L 2400mm)
1,230.00
Master Bath
To design and construct vanity cabinet in laminate finish c/w solid surface top. (L 800mm)
690.00
To design and construct vanity cabinet in laminate finish c/w mirror on doors. (L 800mm)
590.00
Common Bath
690.00
590.00
Sllower Screens
To supply and install fixed shower panel at Master Bath.
490.00
To supply and install corner unit sliding glass shower screen at Common Bath.
1,200.00
Door Works
To supply and install semi-hollow doors in veneer finish to 2 Bedrooms.
760.00
To supply and install tempered glass swing doors at 2 Baths.
1,500.00
Option to install PO door at 2 Baths. ($900.00)
Plumbing Works
To supply and install stainless steel pipes for gas heater.
180.00
To install kitchen sink and tap with supply pipe and waste pipe connection.
180.00
To dismantle old basin and install new basin and mixer at 2 Baths.
240.00
Others
To supply labour to paint whole unit's interior only, with ICI paint, Max 5 colors. (Minimum 2 coats)
1,100.00
To provide labour and material to lay protection board and plastic cover for renovation work.
FOC
To provide labour and material to do professional cleaning for whole unit after renovation, includes cabinet interiors, windows and doors. (2 trips)
FOC
Project management and site coordination services.
FOC
Edited by Coaser85
  • 1 month later...
It's actually quite expensive! It's 20% more than my contractor
may i have your contractor contact? Thanks.
  • 3 weeks later...
Hi All Expert,
800.00
Masonry Works
400.00
450.00
600.00
2,850.00
Carpentry Works
Kitchen
2,380.00
1,960.00
980.00
460.00
1,390.00
1,050.00
Walk-in Wardrobe
5,320.00
750.00
1,200.00
Master Bedroom
1,230.00
Master Bath
690.00
590.00
Common Bath
690.00
590.00
Sllower Screens
490.00
1,200.00
Door Works
760.00
1,500.00
Plumbing Works
180.00
180.00
240.00
Others
1,100.00
FOC
FOC
FOC
hi,
i just had my BTO in woodlands done by my contractor. maybe you can give him a shot? reasonable price and responsible person. do PM me if you need his number. :)
Cheers!
  • 3 weeks later...
  • 2 months later...
hi,
Cheers!
Hi can pm me details?
Thanks
i think he is putting a knife straight at yr throat. mayb u can try spaceart interior design. would say 1 of the cheapest n reliable id in sg. the id in charge for me is bernard, quite friendly n resposible, always clear all my doubts for all thing i ask, mayb u can call him @ 91917203
  • 5 weeks later...
hi,
Cheers!
Hi weiirong
Im a newbie here looking out for affordable contractor for my bto premium flat. I appreciate if you can share with me your contractor number.
Thank u in advance :)
Dora
  • 4 months later...
hi,
Cheers!
Hi, can email me your contractor contact no.?
Thank u!
