pcs83
Advice On Installation Of Air Con Insulation.
I need advice on running the insulation on my false ceiling.
As I'm doing false ceiling at the passageway toward the bedroom. Is it possible to ceiling mount the insulation with trunking rather than wall mount the insulation including trunking.
Thanks in Advance
Yes it can be done direct on ceiling but
U'll need to install L bracket to hold the trunking
End of the day its all about cost :jawdrop:
Mount on ceiling will u able to svc or change the A/C piping if leak to me practical not beautify
Best, aircon system (trunking) comes in b4 false ceiling.
If trunking is against the wall, then there should have no issue....cosmetic issue or maintenance access issue more important?
