Scullymulder
3 Room Resale Flat Quotation - Is This Reasonable?
would like to check if this quote reasonable for a 3 room resale flat.
thanks!
Sorries for the misalighment, have tried a few times adjusting but without success.
A: DEMOLITION & HACKING WORKS
Price
1
To hack & dispose the following items to govt dumping ground (subjected to on-site assessment &
HDB's approval)
Masonry/Flooring
i) Master Bath wall & floor tiles ii) Common Bath wall & floor tiles iii) Kitchen wall & floor tiles iv) Both Bedrooms, Living Room & Store Room laminated flooring
v) Terrazzo skirting for Both Bedrooms, Living Room & Store Room
Carpentries/Misc
i) All sanity fittings & carpentries, if any, in both Baths ii) All existing window grilles
Doors
i) Both Bedrooms' door ii) Both Bath's door & door frames
B: MASONRY / FLOORING WORKS
$ 3,900.00
2
To supply & provide labour to install High-End Resilient Flooring (HERF) to Living Room, both
Bedrooms & Store Room
Kitchen
$ 4,071.00
3
To construct a straight kitchen cabinet concrete base - 3900mmL with side tiled edges of 50mmHt
$ 410.00
4
To supply homogeneous floor tiles - 600mm x 600mm ($3.00/sf)
$ 600.00
5
To supply & provide labour to screed, waterproof & lay homogeneous floor tiles
$ 1,140.00
6
To supply homogeneous wall tiles - 300mm x 600mm ($3.00/sf)
$ 1,483.00
7
To supply & provide labour to screed, waterproof & lay homogeneous wall tiles
Master Bath
$ 2,737.00
8
To supply homogeneous floor tiles - 300mm x 600mm ($3.00/sf)
$ 155.00
9
$ 800.00
10
$ 834.00
11
$ 1,480.00
Common Bath
12
$ 132.00
13
$ 797.00
14
$ 782.00
15
$ 1,404.00
C: MAKE GOOD WORKS
16. To make good hacked wall surfaces derived from hacking of wall terrazzo skirting in order to prepare for $ 637.00
HERF
D: CARPENTRY WORKS Living Room
17. To design & construct a TV console - 1500mmL x 500mmD x 300mmHt in laminate finish$ 800.00
Master Room
18. To design & construct a straight full-height wardrobe with swing door - 2100mmL x 600mmD in laminate $ 1,680.00 finish
Kitchen
19
To design & construct a straight bottom kitchen cabinet with swing doors - 3300mmL x 34"Ht x
600mmD in laminate finish
$ 1,320.00
20
To design & construct a full-height oven larder unit with swing doors - 600mmL x 600mmD in laminate finish
$ 720.00
21
To design & construct a straight top-hung kitchen cabinet with swing doors - 3300mmL x 1000mmHt x
330mmD in laminate finish
$ 1,320.00
22
To supply & install a straight solid surface kitchen top - 3300mmL x 600mmD x 40mmthk front flat drop
& 50mmmHt backsplash (subjected to model selected)
$ 1,059.00
23.To design & construct a sliding door - 800mmL x 2100mmHt in laminate finish
Master Bath
$ 1,100.00
24
To design & construct both a straight 600mmL solid surface top & a wall-mounted vanity cabinet with swing doors in laminate finish & a wall-hung storage cabinet with a swing door in mirror finish (600mmL x 3'Ht)
$ 1,228.00
E: DOOR WORKS
25. To supply & install 2nos of white-powder coated bi-fold door to both Baths' (subjected to model selected $ 379.00& size variation)
26. To supply & install 2 nos of classic model swing door to all 2 Bedrooms c/w standard round headed$ 546.00door knob (subjected to model selected & size variation - existing door frame to remain)
F: GLAZING WORKS Master Toilet
27 Supply & install a 180-degrees swing frameless clear tempered glass shower door with a fixed panel$ 584.00glass - 10mmthk to shower area
G: ELECTRICAL WORKS
28
To run electrical works as per attached schedule 1,565.00
G: Plumbing work
29
To supply labour to run all cold piping & plumbing works for entire renovation job (exposed piping) - only $ 2,300.00
hot piping to both Baths (inclusive of installation of 2 nos of instant heaters)
I: MISC WORKS
30
To supply labour to do area cleaning to entire house
J: WINDOW GRILLES WORKS (subjected to model selected)
$ 650.00
31
To supply & install a 3-track sliding powder-coated alumimium window grille at Kitchen
$ 329.00
32
To supply & install a 2-track sliding powder-coated alumimium window grille at Master Room
$ 219.00
33
To supply & install a 2-track sliding powder-coated alumimium window grille at Bedroom 2
$ 384.00
34
To supply & install a 2-track sliding powder-coated alumimium window grille **** Room
K: WINDOW WORKS (colour of glass as per HDB's requirement)
$ 384.00
35
To supply & install a 3-track sliding powder-coated alumimium windows without top hungs at Kitchen
$ 563.00
36
To supply & install a 2-track sliding powder-coated alumimium windows without top hungs at Master
$ 375.00
37
To supply & install a 2-track sliding powder-coated alumimium windows without top hungs at Bedroom 2 $ 656.00
38
To supply & install a 2-track sliding powder-coated alumimium windows without top hungs ****$ 656.00
Total : $ 40,179.00
Dollars : Forty Thousand One Hundred & Seventy-Nine Only
OPTIONAL ITEMS:
Demolition & Hacking
1
To hack & dispose all items listed in item 1 above except laminated flooring at both Bedrooms, Living
Room & Store Room
Masonry/Flooring
$ 3,060.00
2
To supply & provide labour to install High-End Resilient Flooring (HERF) to both Bedrooms only
Living Room/Store Room
$ 2,095.00
3
To supply homo 600mm x 600mm floor tiles ($3.00/sf)
$ 934.00
4
To supply & provide labour to screed and lay homo 600mm x 600mm floor tiles ($3.00/sf) with skirting
Master Room
$ 2,151.00
5
$ 515.00
6
Bedroom 2
$ 838.00
7
$ 515.00
8
Kitchen
$ 838.00
9
To construct a refrigerator & washing machine concrete base - 1000mmL & 800mmL respectively with side tiled edges of 50mmHt
Misc Items
$ 300.00
10
To make good any damaged wall surfaces, if any
$ 500.00
11
To design & construct a box-up to conceal existing sewage pipes in laminate finish (upon siteassessment)
$ 400.00
12
To supply labour to paint whole house unit wall & ceiling using Nippon/Delux paint
$ 1,800.00
thanks!
Price
1
HDB's approval)
Masonry/Flooring
Carpentries/Misc
Doors
$ 3,900.00
2
Kitchen
$ 4,071.00
3
$ 410.00
4
$ 600.00
5
$ 1,140.00
6
$ 1,483.00
7
Master Bath
$ 2,737.00
8
$ 155.00
9
$ 800.00
10
$ 834.00
11
$ 1,480.00
Common Bath
12
$ 132.00
13
$ 797.00
14
$ 782.00
15
$ 1,404.00
C: MAKE GOOD WORKS
HERF
Master Room
Kitchen
19
$ 1,320.00
20
$ 720.00
21
$ 1,320.00
22
$ 1,059.00
Master Bath
$ 1,100.00
24
$ 1,228.00
E: DOOR WORKS
G: ELECTRICAL WORKS
28
G: Plumbing work
29
I: MISC WORKS
30
$ 650.00
31
$ 329.00
32
$ 219.00
33
$ 384.00
34
$ 384.00
35
$ 563.00
36
$ 375.00
37
38
Total : $ 40,179.00
OPTIONAL ITEMS:
1
Room & Store Room
Masonry/Flooring
$ 3,060.00
2
$ 2,095.00
3
$ 934.00
4
Master Room
$ 2,151.00
5
$ 515.00
6
Bedroom 2
$ 838.00
7
$ 515.00
8
Kitchen
$ 838.00
9
Misc Items
$ 300.00
10
$ 500.00
11
$ 400.00
12
$ 1,800.00
Some of the carpentry work seems to be a bit higher as compare to mine. If you need my contractor quote can just pm me. I will send u his no and u can contact him for a free quotation. :)
