Aircon Installation Best Price
Hi Chris,
Please quote me ME System4
3 X 9000 BTU
1 X 1800 BTU
To replace my existing LG System 4. HDB 5RM
Can the old pipe be re-use?
Thank you.
Regards,
Desmond
I have just PMed to you. Thanks for your enquiry.
Hope can hear from you soon :)
Regards,
Chris
  • Replies 1.1k
  • Views 185k
  • AirconBestValue
    AirconBestValue
    Hi MSTan, PM done, thank you for enquiry. Regards, Chris
  • AirconBestValue
    AirconBestValue
    Hi aquanark, I have just PMed to you. Thanks for your enquiry. Hope can hear from you soon Regards, Chris
  • AirconBestValue
    AirconBestValue
    Hi, I cannot pm you message,it is full main in your inbox??
Posted Images
Hi
I am looking for a System 4 for my new BTO. Looking at 3X 9K + 1x 18K BTU.
Prefers Panasonic/LG/Samsung
please give me a quote, thanks!
Edited by grhu8175
Hi, please give me a quote for the following:
- System 3: 9k X 3
- System 2: 18k X 1 + 9k X 1
Prefered brand of the spec above:
1. Mitsubishi Electric
2. Fujitsu
3. Daikin
Quote shall include installation with:
- Armaflex insulation
- G23 copper pipe
- keystone wire
- 16mm drainage pipe
- System 3: 9k X 3
1. LG
2. Mitsubishi Electric
3. Daikin
Thanks in advance
- System 4: 9k X 3 + 18K X 1
- System 4: 9k X 3 + 22K X 1
2. Carrier
3. Daikin
- Armaflex 1/2 inch insulation
- G22 copper pipe
- keystone wire
- stainless steel bracket
- System 3: 9k X 3
2. Fujitsu
3. Daikin
- G23 copper pipe
- keystone wire
Regards,
Chris
- System 3: 9k X 3
1. LG
3. Daikin
Thanks in advance
Regards,
Chris
2. Carrier
3. Daikin
- G22 copper pipe
- keystone wire
Regards,
Chris
Hi Chris,
Please provide quite for Fujitsu sys 3 aircon + install (AOAG24LAT3/ASAG12LJ + O9LJ x 2).
To remove existing sys 2 aircon/compressor and replace/extend ducting as required
Pls advise the warranty (piping, fancoil,compressor) provided with the aircon purchase and period of coverage for workmanship too.
Thanks.
Hi Chris,
Thanks.
Regards,
Chris
Please kindly quote for a system 4 system with 3 fan coil for my resale unit. Will install the 3 bedroom first and living room will install later. Do note my resale unit loading is only 8.5amp.
- Compresser: 4C100VA
- fancoil: 03 x 9,000 btu
- Stainless Steel Bracket
- removal of old window type aircon
- 20A isolator
- 1 trip installation
Material:
1/2″ Inch Thick Armaflex Insulation Class 1
G23 (0.61mm Thickness) Copper Piping
3 Core 40(fancoil) & 70(compressed} Wire Cable
16mm Diameter Drainage Pipe, 3/8" insulation for horizontal pipes.
Would like a quote for:
System 4 (Mitsubishi Starmex)
27k btu x 1
12k btu x 1
9k btu x 2
3/8" Thick Armaflex Insulation
G22 Copper Piping
16mm Drainage
Inclusive of Installation.
Thank you.
- 20A isolator
Material:
Regards,
Chris
27k btu x 1
12k btu x 1
9k btu x 2
G22 Copper Piping
16mm Drainage
Thank you.
Regards,
Chris
Hi you might have missed my request :)
Prefer Panasonic/LG/Samsung
1/2" Thick Armaflex Insulation
G22/G23 Copper Piping
16mm Drainage
