jmgtan
How To Replace Led Light Embedded In False Ceiling
Check if its the driver that is giving the problem LED downlights dont just "die". The lights should dim to a significant level to signify dying life.
If I'm correct, your LED downlight is a module by itself (ie comes together with the housing). So if you must replace it, then yes, you must remove the whole thing. There should be 2 catches on the housing that latches onto your false ceiling Just remove that. If you're not sure, just go down to a lighting shop to see where the catches are.
