Condo Water Pressure Too High. Causing Leakage. Suggestions
hi guys,
would any of you have any good suggestions to lower the water pressure into our unit? I live in a condo and I think the water pressure is way too high coming into the unit. The condo water riser only have a flow reducing valve, but that doesn't stop the water pressure from building up when no one is using.
it's evident that i keep getting leaking bidets, leaky faucets, and i have some wooden sidings that seem to have water seeping into it.
I read that i can use a water pressure reducing valve? is this a common problem that most plumbers know how to address?
thanks for the help!
  • 3 weeks later...
Pressure does not cause all these leakage.
It is the quality of the sanitary ware and the workmanship that causes the leak.
